Results 1 to 6 of 6
Thread: T80M Consumables
    Mar 2011
    Texas
    T80M Consumables
    I seem to be going through nozzles rather quickly again. Perfect cut angle on one side and then bad angle on the other. The nozzle certainly has a bad burn on one side, but it was new when I started and the problem seems to be throughout the entire plate of 3/8" mild steel.
    I know how to look at the nozzle and electrode to determine when to replace them. And the swirl ring holes get looked at for deposits of junk to determine when to replace that. How do you inspect the retaining cap and shield for issues that would warrant replacement?
    Jan 2008
    The symptoms (varying cut angle, nozzle with a "bad burn" on one side) indicate nozzle orifice damage that is almost always caused by pierce height being too close or pierce delay time being too short. One bad pierce on 3/8" plate can ruin a nozzle....good plate surface sensing and proper pierc height are the best ways to get maximum nozzle life.
    The retaining cap on the Hypertherm torch has internal gas flow passages that route some of the air to the nozzle (plasma gas) as well as some of the air to the shield (shield gas). They are difficult to inspect.....the best troubleshooting method is to change the retaining cap and compare cut quality. A bad retaining cap almost always creates poor cut edge angularity and varying angularity.
    The shield.....the center hole needs to be perfectly round and concentric. The small bleed holes need to be clear and unplugged. Do not use an oxy-fuel "tip cleaner" as this will change the size of the center and bleed holes...which will affect cut quality. The inside of the shield....especially in the area right around the orifice should be carefully inspected for steel blowback. If you see any signs of the material you are cutting inside the shield....then your pierce height and pierce delay times are incorrect. Material blown back between the shield an the nozzle will short these parts electrically....which will double arc the nozzle....which damages the orifice. If there is material inside the shield it often can be cleaned out and polished with scotchbrite.
    Swirl rings wear out over time as well. The holes are drilled at tangental angles...and are very accurately sized. These holes can wear over time. The only good way to determine performance is to try a new swirl ring...and compare cut quality between new and old.
    Typically when machine cutting with a properly functioning height control:
    - The nozzle will wear out twice as fast as the electrode. Depending on the power level, duration of cut and the thickness......and assuming your pierce hieght and pierce delay is 100% correct....you can expect between 400 and 1500 starts on a nozzle.
    -Shields get dirty and should be cleaned periodically as listed above. If the height control is operating 100%....they will last about 5x as long as the nozzle. Clean periodically with scotchbrite and use a small amount of mig welding anti spatter spray on the outside to minimize spatter buildup.
    -Swirl rings and retaining caps should last 50x (or more....mine last about 100 times nozzle life) nozzle life before cut quality deteriation occurs.
    When you do the math...these parts are a bit costly to purchase....but the ultimate cost per foot of cut works out to a few pennies. Typically on 3/8" steel cut with a Hypertherm air plasma the cut cost per foot...which includes consumable use only....is about 3 to 5 cents per foot. Many other brands claim lower cost consumables.....which is true if you only compare purchase price......when comparing cost per foot the Hypertherm systems win hands down.
    Hope this helps,
    Jim Colt
    Quote Originally Posted by Stout View Post
    Mar 2011
    Texas
    Yes. Your reply helped a great deal. I did have a situation at the beginning of this plate, actually the second pierce of this plate, that caused the cut speed on the Micro Edge to change to zero inches per minute. So this second cut would pierce, not move, and then dive into the plate trying to maintain the set arc voltage, and then generate a torch collision error. This happened three times on the second pierce before I realized the change in the cut speed parameter. I did not realize that this might cause a nozzle failure by being too close.
    I will keep an eye on this in the future. I will also try to replace the shield more often also. I've only replaced it once in over 100 nozzles. I just keep cleaning it and it looks good. Although in reality, it may be the cause of some issues that can be easily resolved by it's replacement.
    I need to open a trouble ticket with tech support about this cut speed parameter changing on it's own. I'll try to see what causes it and that will give some indication of a solution.
    Thanks Jim.
    Jan 2008
    Have you looked at the machine code of the part program to see if there was a feedrate hold, or a feedrate speed change? It is real easy to do with hat control.....and the graphic of the part can be on the screen as you look at the lines of machine code....with the features for the line you are looking at highlighted.
    Jim
    Thanks Jim.
    Mar 2011
    Texas
    I don't use feedrates at all. The change seems to be caused by pressing the stop button while the machine is in motion, sometimes. I'll explore this some more when I get the time.
    In the meantime, I will open a trouble ticket. Is there a log of keystrokes on the Micro Edge? That would be the first place I'd start.
    Jan 2008
    Hypertherm tech sevice can direct you to the log that will show keystrokes.
    Jim
    1. T80M Nozzle and Amperage Selection
      By Stout in forum Hypertherm Plasma
      Last Post: 10-02-2011, 02:55 PM
    2. Nd YAG consumables.
      By KPBadger in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-07-2010, 07:22 AM
    3. consumables
      By grogsroom in forum Hypertherm Plasma
      Last Post: 12-18-2009, 08:44 AM
    4. consumables
      By cstroke in forum DynaTorch
      Last Post: 02-07-2008, 10:20 AM
    5. where to buy consumables
      By tuknrm in forum General Waterjet
      Last Post: 02-14-2007, 02:04 PM
