| Hypertherm Plasma Discuss hypertherm plasma machines here. |
Just last fall we purchased a Multicam 3000 unit with a Hypertherm 130 on it. We have been learning alot with it as we go on settings and such. One thing we are having troubles with is the speed of the unit. We use the EZ-Gcode software that came with the unit for nesting and tool path creation. It is quick and easy to use. What i would like to do is find a way to cut down on the number of pierces on the parts. By doing so this should speed up production somewhat. Right now we use the "preset" output for the feeds and speeds that hypertherm uses and we get very good cut quality. I was told by multicam i can deviate from these settings some but it may sacrifice quality. What i am looking into is there an easy way for when nesting parts that dont have any internal holes in them to do away with the pierces and up and down motions after each part is cut? Basicly what i want it to do is come down and make one pierce and then go from part to part and never raise off the part till its done with all the ones on that sheet. Any advice or help on this is appreciated. Thanks Andy |
| Andy, What you are looking for is the chain cutting function in your Cam nesting software. I am not overly familiar with the EZ-Gcode software that you are using....so I sent an email to a friend of mine that happens to work for MultiCam....I am sure he will get back to me soon. Hypertherm has CAM software that can easily do what you need to do...and more....however lets see if what you have will improve your process as well. Here is a link to the MTC software that is offered by Hypertherm....we closely link the CAM software to the other Hypertherm components in the system....and MultiCam works with this software as well. Nesting & Process Optimization Software | Hypertherm Best regards, Jim Colt
| Andy, Kris at Multicam indicated that he had responded to you as well. Jim |
I am new here and cant find the appropriate place to post this question, sorry if this is not the place. I have run pro nest for several years, or at least have personnel that have operated it for awhile. Recently in the pipe program of pro nest I started seeing discrepancies when creating a flat pattern for a square to round transition all of the transitions that I layout are about one material thickness off. I see a for 4 inch od 14ga. tube the flat pattern should be 12.2704 long in the flat, pro nest is generating 12.3289. I can cheat it by changing the base size, OD size, etc and my flat patterns come out correct. It acts like there is a K factor that is not correct, but I have no idea if they work with a K factor or not. I guess I am looking for any suggestions that might help with a remedy for this. |
| Stimey, I would suggest you contact MTC tech service directly...they will be happy to help answer your questions....or if you want send me your contact info to my direct email and I'll ask them to contact you directly. Jim Colt Hypertherm jim.colt@hypertherm.com MTC direct contact: United States 22 West Main Street, Lockport, NY 14094 Phone: +1 (716) 434-3755 Fax: +1 (716) 434-3711 Email: NA@hyperthermCAM.com
| Stimey I'd be happy to see what we can do. Please send me an email stephenm@mtc-software.com I will see what we can do. Stephen McDonald North American Sales Manager MTC Software |
#11
#12
| Thanks for the idea though! Andy |
| Need Help!- FANUC VELOCITY CONTROL UNIT MOTOR SPEED SETTING | keyancnc | Fanuc | 0 | 12-19-2011 07:21 AM |
| Configuring steps/unit.....what unit? | HereinCS | Mach Software (ArtSoft software) | 2 | 03-07-2011 07:57 PM |
| Need Help!- FANUC 15-MA Battery unit & I/O unit etc | gbowne1 | Fanuc | 0 | 05-04-2010 08:47 PM |
| Increasing spindle speed | RP Designs | General Metal Working Machines | 0 | 05-07-2009 12:57 PM |
| Increasing torque | bunalmis | Stepper Motors and Drives | 1 | 07-20-2005 01:27 PM |
