Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 01-29-2012, 11:24 PM
rideright is on a distinguished road
Powermax 45 T45v Torch ?
I just purchased a Powermax 45 with a T45v torch. I will be using it on a Plasmarout CNC table and was wondering what the consumables I need are. I think it will be the shielded nozzle #220671 with shield #220674 it looks like all the electrodes are the same. Let me know if I am wrong or on the right track. If you use something different and it works good let me know that to. I am new to Hypertherm changing from Thermal Dynamics.
Old 01-30-2012, 08:33 AM
jimcolt is on a distinguished road
You should follow the specs listed in the operators manual for the Powermax45.....use the cut charts and consumables listed for the mechanized torch (even though the T45V is a hand torch). It is particularly important to use the machine torch shield (as you have listed, part number 220673) for mechanized cutting to maintain proper torch to work distance.
45 amp shielded consumables for mechanized cutting:
Shield: 220673, Retaining cap: 220713 (if your height control uses "ohmic contact for finding the plate use 220719), Nozzle: 220671, Swirl ring: 220670, Electrode: 220669.
There also is a set of 30 amp consumables for cutting between 20 and 30 amps for materials thinner than 10 gauge...these unshielded consumables will allow for slower speeds and thinner kerf width. To use these consumables you need to order all of the components...Retaining cap: 220483, Nozzle:220480, Swirl ring: 220479, Electrode: 220478 (you do not need the deflector)....these are the same parts as used in a Powermax30 torch.
Best regards, Jim Colt Hypertherm
Powermax 65 machine torch on Torchmate 2 FunWestTexan Hypertherm Plasma 1 01-18-2012 08:39 AM
Machine torch for Powermax 600/800/900 for sale jasonpaulbauer Hypertherm Plasma 0 12-14-2011 09:44 AM
T60 Torch on a Powermax 1250 Stout Hypertherm Plasma 1 08-04-2011 04:26 PM
Powermax 85 Machine Torch, any breakages? BioHazard73 Hypertherm Plasma 18 03-14-2011 09:05 PM
CandCnc + Powermax 45 + Machine Torch = brouser1 Plasma, EDM and other similar machine Project Log 19 06-09-2010 04:27 PM
