Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 11-08-2011, 03:28 PM
adscnc is on a distinguished road
Powermax 85 and 1.5mm stainless
Hello Jim
Can you reCommend some cutting data?
Using a CandCNc system with a PM 85, can cut at 7m a min, mechanised system with a machine torch with digital torch height control.
With these parameters where would you start , maybe fine cut consumables at what sort of speeds and heights?
Old 11-09-2011, 08:28 AM
jimcolt is on a distinguished road
I would recommend the specifications right out of the Powermax85 operators manual....and best cuts would likely be using the consumables and specifications for the Fine Cut consumables......although the 45 amp shielded parts will do almost as nice of a cutting job (slightly wider kerf, faster speeds, longer consumable life).
The Finecut parts will need about 6.4 meters/min....the 45 amp shielded specs are listed for about 8 meters/min on 1.5mm stainless....but the process is pretty forgiving and will work at slower speeds.
If you do not have the cut charts or the manual I can forward them through direct email...this site will not let me paste a cut chart directly...
Jim Colt jim.colt@hypertherm.com
Originally Posted by adscnc View Post
Hello Jim
Stainless or non stainless steel ACME screws? amanmazleigh Linear and Rotary Motion 1 07-06-2011 11:00 PM
powermax 45 or 65? dhaddox Hypertherm Plasma 1 01-01-2011 07:46 AM
cutting Thin stainless sheet Powermax 45 adscnc Hypertherm Plasma 10 10-27-2010 05:44 AM
Cutting 11 ga stainless with Hypertherm PowerMax 1250 J-Gro Hypertherm Plasma 3 06-29-2010 07:05 PM
30 amp or 45 amp Powermax 45 adscnc Hypertherm Plasma 1 03-08-2010 05:23 PM
