Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 11-04-2011, 07:54 PM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
Oil in a T100M torch line help
How do we clean or minimize the oil that has managed to get in the line of a Hypertherm air torch? I removed my oil filter thinking My compressor was not leaking any oil into the lines (needed to make some room), well not so. Finding small amounts of oil on the swirl ring now and it coincides with decreased nozzle life, down to 800 pierces from 1500 pierces on 3/16".
Can we use alcohol or something equally as explosive to clean out the oil?
Thanks,
WSS
www.metaltechus.com
Old 11-05-2011, 07:38 AM
jimcolt is on a distinguished road
I would suggest talking with Hypertherm tech service directly...I'm sure they have run into this issue before.
Jim Colt Hypertherm
Old 11-08-2011, 08:35 PM
AK-47 is on a distinguished road
Hi WSS,
If your compressor not leak, do you find where the oil comes from?
I think it is because you removed your oil filter.
Use some dishwashing liquid to clean the line and mount the filter on.
Then check it again.
Not use alcohol or fuel to clean, it can damage to the line.
John
T100M PIP switch WSS Hypertherm Plasma 7 03-17-2011 01:23 AM
Hypertherm T100M Machine Torch Cable diameter Zaher Hypertherm Plasma 5 01-24-2010 03:53 AM
Hypertherm T100M Machine Torch Cable diameter Zaher CNC Plasma and Waterjet Machines 0 01-18-2010 07:29 AM
Need Help!- SDS/2 and Arianna for Ficep Drill/Torch Line sippelsteelfab1 General Metal Working Machines 1 10-01-2009 02:44 PM
Hypertherm 1250 with a T100M torch??? Short consumable life Brink_ CNC Plasma and Waterjet Machines 18 01-08-2009 10:28 AM
