Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 10-17-2011, 05:57 PM
Edwardo is on a distinguished road
machine to manual torch
I bought a used hand held torch quite awhile ago and who ever had it before modified the wires for cnc cutting, now i have a guy rewiring it to function as a hand held again. My 1250 is set up with a machine torch on my Dynatorch table but i want to be able to unplug that and plug the hand held in for free hand cutting so my qusetion is once i unplug the machine torch and plug in the hand held is there anything else that needs switched over?
EDD
Old 10-18-2011, 08:07 AM
jimcolt is on a distinguished road
As long as the torch wiring is back to the factory specs....it will work as soon as you plug it in. Let me know if you have any issues!
Jim Colt
Old 10-22-2011, 11:28 AM
bdrotaru is on a distinguished road
Jim Colt
How do I connect relay from mach3 system to cnc interface???
Old 10-22-2011, 02:16 PM
The rear panel of your Powermax1250 has a CPC (circular plastic connector)....it is for interface connections to the cnc control when a machine torch is being used. Pins 3 and 4 on this CPC are the plasma start connections. When pins 3 and 4 are shorted together...the machine torch will fire.....assuming air pressure, input power and consumable parts are all set up correctly.
As far as the exact connections to your relay and Mach 3.....I am unfamiliar with your system......you should probably consult with the company you purchased it from for details regarding the interface.
The Powermax1250 manual has a section regarding the electrical interface connections for use with a machine torch.
Jim Colt Hypertherm
Wanting to change my Hand Torch to a Machine Torch?... winegar Plasma, EDM and other similar machine Project Log 5 07-22-2011 10:56 PM
Machine Torch P/N sodfarmer Hypertherm Plasma 1 11-09-2010 06:49 AM
Hand torch to machine torch matttargett4 Hypertherm Plasma 10 06-01-2010 03:37 PM
hypertherm 1000 hand torch to machine torch duraflap Hypertherm Plasma 4 05-18-2010 02:34 PM
Need Help!- Different between hand torch& machine torch ltran2000 CNC Plasma and Waterjet Machines 7 03-02-2008 09:19 AM
