Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 10-01-2011, 06:45 PM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
Air Plasmas and Water tables......
We just added a water table on our cutter that has a Hypertherm 1650 and have noticed shorter consumable life in both nozzles and electrodes. The torch has never been dunked but it does sit over the water at night, is this a possible spot for water contamination? What are the general thoughts on air plasma over water? An interesting coincidence is I purchased a bunch of "surplus" OE electrodes on ebay and they arrived stuffed in a box and pretty dinged, I have to check each one for nicks before installing
Thanks for any input.
WSS
www.metaltechus.com
Old 10-02-2011, 07:25 AM
jimcolt is on a distinguished road
Unless water is actually getting inside the torch...then it should have no effect to consumable life. The "Surplus" electrodes.....if they truly are Hypertherm consumables they will have a Hypertherm part number and date code....and on some of them, a system designation or amperage rating laser etched on them. Consumables are manufacturered to some pretty tight tolerances....nicks and scratches will affect operation and life.
Jim Colt
Important info for plasmas with water table (Torchmate & others). xavier2nd CNC Plasma and Waterjet Machines 25 10-25-2011 03:20 PM
CNC Plasma Cutting Cutter Water Tables Machines CNCadmin EBAY ADS 0 05-26-2011 10:50 AM
CNC Plasma Cutting Cutter Water Tables Machines CNCadmin EBAY ADS 0 05-04-2011 05:00 PM
How deep did you make your water tables? microdot Plasma, EDM and other similar machine Project Log 7 01-02-2010 12:44 PM
Water Tables..... ben88ner Polls 1 06-07-2009 09:33 PM
