| Hypertherm Plasma Discuss hypertherm plasma machines here. |
We are running a controlled automation cnc plasma cutter with a standard HPR260 power unit and command THC with auto-gas and are getting a dialog box appearing pretty regularly that says "GetHPRprocessinformation" When we hit the "OK" button it returns to running normally. Does anyone have any idea what this is and what the cause might be? Thanks, Greg |
| You will have to contact Controlled Automation. The Hypertherm HPR auto gas control operates from a serial connection that comes from Controlled Automations PC based CNC control.....Controlled wrote the code to communicate with the Hypertherm systems and it sounds like there may be some sort of a glitch with communication. You can also contact Hypertherm tech service....although I suspect they may send you to Controlled. Jim Colt Hypertherm |
| Newbie- Solidworks files result in "Entity Not Found" Error Messages... | Pophamrt1 | EdgeCam | 6 | 08-15-2011 03:23 PM |
| Mazak T-2 "20 NMI Emergency Stop" Error" | Jeff_Y | Mazak, Mitsubishi, Mazatrol | 13 | 01-11-2011 10:35 AM |
| "Runtime error 9 - subscript out of range" on Techno CNC interface | zhoudfoster | General CNC (Mill and Lathe) Control Software (NC) | 4 | 10-25-2009 10:57 PM |
| OM-A ROM PARITY ERROR "NOT RAM ERROR" | offroadxx | Fanuc | 9 | 05-07-2008 08:15 PM |
| V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" | rfdoyle | Bridgeport and Hardinge Mills | 4 | 10-08-2007 03:35 PM |
