Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 03-17-2011, 10:17 AM
rtsplace is on a distinguished road
Thumbs up Torch Height ?
Hi, Is there an ideal torch, for all thicknesses or does it vary by thickness?
I'm running a 1250 powermax G-3 on a CNC table I just got running.
Old 03-17-2011, 08:21 PM
Benderart is on a distinguished road
I'm not really sure what you're asking.
If you mean cut height, your Hypertherm manual has recommended cut heights for different thickness materials, consumables, etc.
If you're asking what torch to use, Hypertherm have just released new Duramax torches that would suit your application.
I know Jim Colt can steer you in the right direction
Old 03-18-2011, 06:47 AM
jimcolt is on a distinguished road
For your Powermax1250 for mechanized cutting....if you look at the cutting parameter charts in the operators manual...you will find that the cut height for the 40 amp, 60 amp and 80 amp shileded processes are all the same, at 1/16". Pierce height will vary through the material thickness range. The Fine Cut consumables require a couple of different heights depending on materials type, .08" for carbon steel and .010" for stainless steel.
Variation from these heights due to plate warpage, slats that are not perfect etc will affect cut quality in terms of dross and edge angularity....height should be controlled to the above specs within about .005". An automatic torch height control system that sets the correct pierce height then immedately after piercing indexes down to the cut height, and maintains the proper cut height using arc voltage feedback...is necessary for good quality cuts as well as long consumable parts life.
Jim Colt
Old 04-03-2011, 01:15 PM
ratpack is on a distinguished road
Need Help!!!
How to choose a Good TORH HEIGHT CONTOLER?
I have a Termal Dynamic 101 Plasma Max 80amps. I am running Mac3 and looking for a torch height conroler that will change torch height whean maretial worps, i am cutting over a water table.
Old 04-03-2011, 01:20 PM
Go to www.candcnc.com . They build THC systems that work with Mach 3. Talk to Tom Caudle, tell him what you have and he can help your select the best components for your needs.
Jim Colt
Old 04-03-2011, 03:09 PM
Red face
Thank you Jim that was a fast reply, again many thaks.(Peter F.) from Winnipeg,Mb. Canada
DIY torch height control mjp CNC Plasma and Waterjet Machines 34 12-20-2009 02:57 AM
Need better torch height control? Karl_T CNC Plasma and Waterjet Machines 4 04-27-2009 11:36 AM
torch height help marcmnrsports Plasma, EDM and other similar machine Project Log 0 09-01-2008 01:45 PM
Question on torch height wiwoods Plasma, EDM and other similar machine Project Log 1 02-19-2008 05:20 PM
Torch Height Control luther Plasma, EDM and other similar machine Project Log 4 07-12-2007 03:51 PM
