Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 03-16-2011, 03:43 PM
adscnc is on a distinguished road
Cutting 1" with 1650
We are mechanised piercing and cutting some 1" mild steel plate with a 1650. g3
I know its not recommended to pierce but if you had to...
Do you have any tips ?
We're getting a lot of metal splatter on the shield... this is the worst bit.
Old 03-16-2011, 04:48 PM
Benderart is on a distinguished road
Drill pilot holes where your pierce points are.
I also use a 1650 and, cut some 20mm plate a couple of years ago, complete with many pierces and, wasted so many consumables, I drew a line in the sand and, now don't pierce anything over 16mm.
Mick.
Aussie
Old 03-17-2011, 06:35 AM
jimcolt is on a distinguished road
You will not be able to pierce 1" plate with a Powermax1650 without damaging the shield and nozzle. It's maximum pierce capacity is 3/4". Drilling pilot arc holes is the best way to achieve 1" cutting...or edge starting. We normally recommend a 200 Amp plasma for the ability to pierce 1" materials.
Jim Colt Hypertherm
Old 03-17-2011, 10:28 AM
1" plate
Jim
We want to cut a 40mm hole in 25mm plate, we are going to drill a 5mm pilot hole right on the circumference of the circle and start and finish inside the drilled pilot hole... what size hole would you drill ?
Is this the best way of doing this ?
A boss will be welded in the 40mm hole , so the 5mm hole will be filled with weld. If there's anything left of it !
The hole is over size so some taper isn't going to matter.
Old 03-17-2011, 11:47 AM
Any hole larger than about .100" (2.5 mm) will work fine. Make sure the nozzle orifice starts on the edge, make sure you program a pierce delay time to allow the arc to stabilize before movement starts.
jim
New Machine Build- JF's 36" x 48" Solsylva build for tangential knife cutting. jfmonod DIY-CNC Router Table Machines 5 09-04-2010 08:14 AM
Need Help!- HYPERTHERM 1650 100AMP CUTTING suzukirmz CNC Plasma and Waterjet Machines 2 10-13-2009 09:23 PM
modifying Carbide endmill shanks"cutting them shorter" kojack Metal Working Tooling 6 05-26-2009 11:08 AM
Need A Quote- Wire for foam Cutting "EdgeSweets" machine singerdon49 Employment Opportunity 0 12-29-2008 08:12 AM
Why is the cutting bit taking the "scenic tour"? BrassBuilder Dolphin CADCAM 5 03-17-2008 09:58 PM
