If this is in a 65 or 85 unit the two leads go through the the lower serated hole inthe plastic and the smaller on hooks the the backside of the main board and the bigger one hooks to the backside of the main board higher up about 6 inches. It is easier to see where the two little plugs go if you unscrew the bottom of the front and use a flat screwdriver on the little metal tab on the bottom to pull the face away from the main body 1". You should have gotten a field install guide with your divided tip volts card. It also screws into the plastic where the two little hole standoffs are on the fan side.
LinkBack URL
About LinkBacks
