Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 02-14-2011, 07:30 PM
Kentuckyfarmer is on a distinguished road
Questions for Jim 45 vs 65
Jim I know the 65 is bigger will cut thicker material etc. My question is does the 45 have a easy way to connect dthc to it or do you have to get inside of the machine.
I looked at hypertherm web site but did not find a answer.
Is the machine torch a option on both models? Although the more I think about it I cant really see a good reason to use the machine torch on a cnc table when so many of the ones in the build log have hand torchs clamped to them. And I can use it by hand if needed.
Does the 45 have quick disconect torch?
What am I missing?
Thanks any advice will be of a help
Mike
Old 02-15-2011, 06:38 AM
jimcolt is on a distinguished road
Both the 45 and the 65 have machine torches available, and both have quick disconnect torches. The machine torch is easier to square to the plate, and when the machine torch is plugged in the rear panel interface connections are active. For safety reasons, the start signal on the rear panel connector will not function with a hand torch installed....so if you use a hand torch on a machine application you will have to open the plasma and cut and splice wiring to make it work, bypassing the safety trigger on the hand torch.
As far as connecting to a torch height control....it depends on the torch height control. Both the 45 and the 65/85 have voltage divider outputs available on the rear panel interface connector, also have start signals (active with the machine torch only) on the rear panel connector, and have an arc transferred (also known as arc good) output on the rear panel connector. Many torch height control systems require "raw arc voltage".....which can be as high as 300 volts DC.....and that output must be accessed by removing the cover on any plasma system....as the voltage is too high to meet CSA, and other electrical safety requirements to be accessible on the rear connector.
Jim Colt
Old 02-15-2011, 06:17 PM
Thanks Jim
The DTHC is coming from Tom at CandCnc if that helps
Thanks Again
I have looked at most brands in the last day or so, it seems in central ky hypertherm rules, most suppliers dont even carry anything else.
Old 02-16-2011, 06:42 AM
The Hypertherm systems are not always the cheapest to buy....but like any good tool will prove to be the best value over time...you won't be disapointed with the product or the support!
Jim Colt
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 12:40 PM
Newbie- 3 questions, maybe 4 Tubeguy54 Benchtop Machines 5 09-28-2008 11:14 AM
new with PET-G Questions cadence Vacuum forming, Thermoforming Etc 1 09-27-2007 05:21 PM
TM-2 questions Zeekh Haas Mills 14 12-03-2006 09:01 PM
