Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 02-09-2011, 01:52 PM
jcizek is on a distinguished road
Powermax 380 signals
Hi everyone, after much searching I cannot seem to find the answer to this one. Does anyone know if a Powermax 380 has an "arc ok" type of signal available in it? I found the manuals, and the maintenance docs on it, but they do not have full schematics that I can tell.
Just wondering if there is easy access to this signal, or if I will need a current transformer to provide this signal for a THC. Seems like it's a good idea to have this, I am just finishing development on my homebuilt PIC-based THC and could leave this feature out of the code, but from what I read, it's a good idea to have the THC able to shutdown the plasma if there are arc problems.....
Thanks. -James
Old 02-10-2011, 09:10 AM
jimcolt is on a distinguished road
Since the Powermax380 was designed and marketed by Hypertherm as a hand held plasma cutting system....it does not have any internal method of indicating that the arc is transferred to the plate (also known as "arc good", "arc transfer", "machine motion").
The best way is to install a current sensor (Tom at C and CNC electronics sells them) on the work cable that clamps to the metal you plan to cut. Whenever the torch is cutting platre there is cutting current on this cable.....
Jim Colt Hypertherm
Problem- Ask for Fanuc OM-A M1/M2 connector signals david_chen Fanuc 7 03-18-2011 03:59 AM
Ask for Fanuc 10M/T DI/DO connector signals Jung Fanuc 2 12-26-2007 08:59 PM
NC414 Controller Signals krz2_2000 Bridgeport and Hardinge Mills 0 08-30-2007 07:03 AM
Multiple Signals on a Cable cibressus General Electronics Discussion 7 08-19-2006 05:59 PM
To convert Quadrature Encoder signals to Tachogenerator signals Babar General Electronics Discussion 4 02-21-2006 12:05 AM
