Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 01-28-2011, 07:49 AM
kjferg is on a distinguished road
Torch is in Lower Limit
Trying to cut a sign out at work, and when the table goes to cut the "S" out it will throw the error "Torch is in LOWER LIMIT on the pendent. I have try moving the work piece around and still same results. I have copy the "S" and placed it on another sheet and it cut it fine.
I'm using a Hypertherm THC on a Vicon table with Vicon cutting system software.
Any help would be awesome.
Old 01-29-2011, 07:42 AM
jimcolt is on a distinguished road
It sounds to me like your torch is in lower limit on the z axis slide of the torch height control, which means you may have a low spot on your cutting table and the height control cannot go low enough to maintain the proper height.
Try adjusting the clamping point on the torch....so that the torch is held lower in the mounting block on the torch lifter assembly.
Jim Colt
Torch touch off / floating torch Ubatoid Plasma, EDM and other similar machine Project Log 15 01-06-2011 11:38 PM
Hand torch to machine torch matttargett4 Hypertherm Plasma 10 06-01-2010 03:37 PM
hypertherm 1000 hand torch to machine torch duraflap Hypertherm Plasma 4 05-18-2010 02:34 PM
Need Help!- Different between hand torch& machine torch ltran2000 CNC Plasma and Waterjet Machines 7 03-02-2008 09:19 AM
