Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 12-15-2010, 05:29 PM
sodfarmer is on a distinguished road
Switch Question 1000
Jim,
I was changing out the consumables on the machine torch and had a problem. The red fault lite is flashing and the power on is green and flashing. When I turn the power switch off, the lites still flash about 15 seconds. Even if I unplug the machine the lites still flash. I also tried my hand torch and get the same results.
John
Old 12-16-2010, 07:07 AM
jimcolt is on a distinguished road
John,
It is normal for the lights to stay active for a few seconds after you power down the unit. The red fault light indicates a fault that could be related to: low air pressure, incorrect consumables in the torch, low input line voltage....and/or quite a few other issues. There is a good troubleshooting flow chart in your operators manual....and if that does not help I suggest contacting Hypertherm tech service...they are free, and they are extremely helpful when it comes to any Hypertherm equipment problems. Here is their contact information:
Technical Service
technical.service@hypertherm.com
800-643-9878 Tel - Toll Free in USA
and Canada
Let us know how this works out....or if I can be of any help. You also can download the service manual directly from the Hypertherm | Plasma Cutters | Plasma Cutting Equipment | Metal Cutting Equipment website.
Best regards, Jim Colt
Originally Posted by sodfarmer View Post
Jim,
John
Old 12-20-2010, 11:16 PM
bakerj99 is on a distinguished road
my 1650 was doing that and i finally got under the cover. just looking and wiggling everything i was the ribbon cable on the outside display to the board. i could wiggle it and it would throw a fault. the VERY generous folks @ hypertherm warranted the part even though the machine had just gone out of coverage. just for that i have bought two more units from them, (nothing wrong with the units other than the cable on the first one, people just offer too much for a used machine and i go and buy a new one for not much more), so if they would be willing to help a poor boy out like that and continue that kind of service/tech support, i dont want to do business with anyone else.
bakerj99
Old 12-21-2010, 03:58 PM
Jim,
I spoke to the tech line and it was alot less painless and cheaper than I thought it was going to be. I believe it is the fan that needs to be replaced. I wish other companies I dealt with had this good of service.
John
Bridgeport VMC 1000/22 Heidenhain, stupid question gus Bridgeport and Hardinge Mills 2 08-23-2011 12:23 PM
TPA Question Arrow 1000 Arrow eeyore Cincinnati CNC 8 05-19-2010 09:59 AM
Cincinnati Arrow 1000 Coolant Question zephyrmachine Cincinnati CNC 3 10-15-2009 07:49 AM
VMC 1000/20 with heidenhain tnc2500b controller question fatass CNC Machining Centers 1 01-13-2006 10:04 PM
Limit switch question bgolash Mach Software (ArtSoft software) 0 06-23-2005 03:05 PM
