Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 12-12-2010, 05:54 PM
sodfarmer is on a distinguished road
Swirl Ring Question
Jim,
I have a Powermax 1000 with a machine torch on a CNC table. Is 120925 the correct swirl ring to use with Fine cut consumables.
thanks,
John
Old 12-12-2010, 07:06 PM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
Yes that is the right part number for the machine torch using fine cut. If you have the fine cut "kit" you might have an extra swirly for the hand held, it has less porting on the exit side if I remember correctly.
WSS
Here is a link to some 1250 settings:
http://files.me.com/izonltd/h6tpy2
It is a 5mb printable pdf
Old 12-13-2010, 07:14 AM
jimcolt is on a distinguished road
John,
WSS is correct on the part number. The manual is a bit confusing as it lists another part number for the FineCut swirl ring.....however that number shoulkd only be used for hand cutting applications.
I also recomend the use of the 220404 deflector for all mechanized FineCut applications...this deflector extends slightly past the nozzle, which helps to eliminate nozzle arcing to the plate.
Best regards, Jim Colt
Old 12-13-2010, 07:37 AM
Jim,
Thanks for the info. I have a questions about the deflector. Does using this help increase nozzle life?
Thanks,
John
Old 12-13-2010, 08:52 AM
Yes, the 404 deflector acts as a double insulator, sort of like the shields used on the 40 amp and higher consumables, which minimizes double arcing in the event that the front of the torch touches the plate while cutting. The life of the FineCut consumables is typically shorter than our regular shielded consumables...as the design of the nozzle has higher energy density which imparts a higher temperature on the nozzle orifice.
Jim
Ring gear micro222 CNCzone Club House 13 02-15-2011 05:50 PM
LED Ring Light Ed Boysun Bridgeport and Hardinge Mills 6 02-01-2009 11:48 PM
How to make a wedding ring? PEU General Metalwork Discussion 3 07-08-2008 04:12 PM
o ring bankshot Work Fixtures and Hold-Down Solutions 1 01-09-2007 08:40 PM
Key ring Klox BobCad-Cam 0 03-15-2005 12:58 AM
