Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 11-29-2010, 10:22 PM
binfordw is on a distinguished road
Powermax 45 help
I've been enjoying my powermax 45 for around 6 months or so now I guess, but have started having some troubles.
Arc starting has progressively been failing more and more often. A month ago, it would only fail to start after sitting a day, now it fails after sitting an hour sometimes, and requires lots of purging and several on/off torch cycles to get it to fire. After that it works normally.
I had some moisture trouble, and only recently added a "motorguard" submicronic paper element filter right next to the plasma unit.
It seems to cut normally on short runs, but when cutting lots of parts, I start to have trouble with inconsistent cuts on some parts, and failed arc starts.
Is there anything I should try to cure this? Have I damaged my plasma unit from using inadequately filtered air?
www.custommetalworking.com
Old 11-30-2010, 02:19 PM
jimcolt is on a distinguished road
I can offer advice that may be causing the issue, but the best advice will come from the Hypertherm tech service staff. The call is free, and they spend their days talking with Hypertherm systems users, and likely will be able to walk you through the issues.
Contact info: Technical Service
technical.service@hypertherm.com
800-643-9878 Tel - Toll Free in USA
and Canada
Here are a few things that can affect starting of a blowback style torch:
1. Electrode and nozzle....have you replaced these?
2. Retaining cap may be overtightened....it only should be snug.
3. Swirl ring...over time these can wear out, which will impede starting. Replace.
4, Retaining cap could need replacement.
5. Inlet air pressure too high. Turn Amps knob fully ccw, adjust air regulator while air is flowing using LED pressure indicator on front panel.
6. If a lot of moisture got in the torch...the torch plunger assembly may need to be disassembled and cleaned. Refer to the Powermax45 Service manual for detailed instructions. Service manual can be downloaded from Hypertherm | Plasma Cutters | Plasma Cutting Equipment | Metal Cutting Equipment, click on document downloads, choose the Powermax45, scroll down to service manual and it will download as a .pdf.
7. Make sure you are using Hyperther genuine parts. Aftermarket consumables have stack up tolerance issues which can cause misfiring.
Jim Colt
Old 11-30-2010, 06:50 PM
Thanks Jim, Ill try those tips.
Im using Hypertherm consumables, and yes, have replaced them recently. I'll try cleaning everything and perhaps order a few of the parts mentioned.
Old 11-30-2010, 07:03 PM
Do you know the PN for the Mechanized Shield cap?
Old 12-01-2010, 07:19 AM
The mechanized shield is 220673. All of the consumables are clearly listed in your operators manual, make sure that you are looking at the mechanized torch cutting chart....when cutting on a machine, regardless of whether you are using a hand torch or a mechanized torch.
If you have misplaced the manual, you can download one. Hypertherm | Plasma Cutters | Plasma Cutting Equipment | Metal Cutting Equipment, click on document download, choose Powermax45 and operators manual, you can download a .pdf copy. If you just need consumable part numbers...go to Hypertherm | Plasma Cutters | Plasma Cutting Equipment | Metal Cutting Equipment, click on products, consumables, consumables by system, and choose your system (any Hypertherm system including those not manufactured anymore)....you can get a complete consumables listing for hand held and mechanized use.
Jim Colt
Old 12-01-2010, 11:52 AM
Thanks. The site I was ordering parts from didn't specify whether it was a drag tip shield/cap or a mechanized one and I couldnt remember the number. I do still have the manual.
I looked through the service manual online about cleaning the plunger setup in the torch, but it didnt show much other than the exploded view of the hand torch assembly.
I think the recent episode of introducing alot of moisture to the unit caused the starting problems to get worse. I ran a very long job a few weeks back, and I think my old filter system allowed alot of vaporized moisture to pass. After that I ordered the better filtration setup but I guess the damage has been done- or it needs cleaned out.
Also- When I start the unit up in the morning, I turn the amp dial to purge it, and it responds very slow, sometimes 3-4 seconds before air starts to flow. After I cycle the purge setting a few times, it starts to respond better.
Old 12-01-2010, 11:57 AM
That may well be your problem....it is the air flow that moves the torch plunger that starts the plasma arc. The air should come on strong and immediately. You probably have a partially plugged or sticking air solenoid valve. Easy to replace and is covered in the tech manual. Gunk that is brought in through the air line can definitly cause this symptom. There also is a filter unit inside the 45 that could use cleaning...
Jim
Old 12-01-2010, 11:05 PM
I spoke with tech support today, and they had me clean the air solenoid. It was dirty/gummy, and the reason for the slow starts. Now it purges normally, and the torch seems to light much easier, but I am still having some trouble with losing arc during a cut. It will momentarily stop and then start again during cutting.
I'm pretty certain its a dirty/oily air issue, just not sure what to clean really- or whats safe to use to clean things.
Old 12-06-2010, 08:08 PM
Still having a pretty frequent problem of the torch losing arc during a cut, it loses arc for a second and restarts.
Any suggestions as to what may be causing this?
Old 12-07-2010, 06:15 AM
If you give me more detail in regards to when the arc goes out...perhaps I can help.
1. Does the arc go completely out (no arc, no air flow) then restarts?
2. Does the arc stay on but does not fully penetrate the material?
3. It looks like your earlier issue was with starting the arc.....now it seems different.....is that correct?
4. What type of cnc machine and control do you have. Height control?
Jim Colt
  #11   Ban this user!
Old 12-07-2010, 11:37 AM
Jim Colt
Yes, sort of a different problem, the torch starts easily now, and cuts well, but the arc shuts off temporarily during most cuts.
As best as I can tell, the arc goes out- but the air is still flowing. Hard to tell with background noise. Cutting stops completely and then restarts on its own. I'll try to do some tests to find out for sure if the air is still flowing when it stops cutting later.
My CNC control is a bladerunner kit, with the included DTHC.
Powermax 45 problems Bigtoy302 Hypertherm Plasma 11 10-01-2011 08:34 AM
30 amp or 45 amp Powermax 45 adscnc Hypertherm Plasma 1 03-08-2010 05:23 PM
PowerMax II connectors Bryanpl Stepper Motors and Drives 16 06-23-2007 11:51 AM
Powermax II Help Bryanpl Stepper Motors and Drives 14 02-21-2007 01:47 PM
Powermax 2 crow General Electronics Discussion 1 04-02-2004 11:09 PM
