Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 11-19-2010, 10:27 AM
iron man is on a distinguished road
need tips on stainless steel cutting on hpr260
need some tips to get better cut quality on 14-11 ga ss with a multicam 6000 table and a hpr260 plasma. getting bad angle on cut and alot of dross. using 45amp F5/N2 process.
Old 11-20-2010, 06:49 AM
jimcolt is on a distinguished road
If you follow the specifications exactly as the operators manual, exact speed, exact gas mixes, exact cut height, pierce height and arc voltage, then you will get the best dross free cuts. The cut edge angularity on stainless steel is normal.....you will not get the same quality of a cut on stainless as you will on carbon steel, because cutting stainless is strictly a thermal (melting) process, while the cutting of carbon steel with oxygen is an combination of thermal and exothermic.
The normal causes of dross on thin aluminum: Incorrect cut height and cut speed being too slow. Stainless is very touchy with both of these parameters. The parameters in the Hypertherm manual are generallya very close starting point.
Jim Colt Hypertherm
Cutting Stainless Steel rbmedic75 PlasmaCam 7 11-10-2010 02:04 PM
Need Help!- CNC Stainless steel cutting PakoNG Want To Buy...Need help! 14 02-11-2010 03:34 PM
Laser Cutting Stainless Steel ??? Babba Laser Engraving & Cutting Machines 21 03-24-2008 06:48 PM
Need Help!- cutting stainless steel YANKS_RINKS General Metalwork Discussion 4 03-21-2008 04:43 PM
Cutting stainless steel andy_ck87028 Mechanical Calculations/Engineering Design 6 09-25-2005 05:14 PM
