Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: Jim Colt, Powermax 65 / 85 questions
  1. #13
    Sep 2005
    Indonesia
    Jim,
    If I want to use Powermax 65 for cnc, can I order the one with handheld torch or should be mechanized torch? If I can use handheld torch for CNC, it will be cheaper. Thanks.
  2. #14
    Jan 2008
    If you use the handheld torch, you will have to figure out how to bypass the safety circuit (it is not that difficult) that is designed to prevent the torch from firing from a remote start interface, as opposed to the trigger switch. Hypertherm employees cannot supply advice on how to bypass this important safety feature.....as it is a safety feature!
    If you use the machine torch, and have a unit with the optional cnc interface plug on the rear panel, then interfacing the system is safe, simple, and quite easy to figure out. The machine torch is easier to square to the plate, and is generally easier to route the leads from. I use a machine torch on my Powermax 45 that is mounted on a PlasmaCam machine, when I wnat to hand cut I unplug the machine torch and plug in the hand torch (less than 10 seconds) and I'm ready to cut by hand.
    Jim Colt
  3. #15
    Apr 2012
    Powermax 65 Machine torch conversion
    I have a Plasma Cam system with the Sampson 510 table. I have been using the hand torch and holder from Plasma Cam.
    Yesterday I received my machine torch and magnetic holder. I quickly installed on my table and thought I was ready to cut. However the torch will not fire, after reading around here and on other forums I see that I need to fire the machine torch through the plasma unit itself due to the fact that the machine torch does not have a trigger wire contact in it, which is what Plasma cam uses to fire the torch. Everyone says to use pins 3 and 4 on the machine interface plug on the rear of the machine. Here is the problem - I don't have that plug! I bought the Hypertherm unit through Plasma cam with the table so I find this odd.
    Is there any way to get around this??? Or did I just waste nearly $1000.00 ??
  4. #16
    Registered quisman's Avatar
    Dec 2008
    jcplater, you will be good to go with a machine interface kit. The part number should be in your manual or your distributor should be able to get you a number as well. The only catch is you will have to take the cover off your machine and install the kit. The directions are well writen and should be able to walk you right through it. Hope this helps and happy easter.
    Edit: here is a link to the service bulletin on Hypertherms website. https://www.hypertherm.com/Xnet/libr...file=HYP103957
  • #17
    Jan 2008
    If you originally bought a hand torch version of the Powermax
    I'm not sure what plasma system you are referring to....if you can clarify that, then I could help.
    If it happens to be a Hypertherm Powermax65 or 85, and you ordered it originally with the hand torch....then it likely is a hand torch system that does not have the CPC interface connector. For hand cutting there is no need or use for the CPC connector. PlasmaCam often sells the hand torch versions as they cost less......and they suggest that you cut and splice thr torch trigger wires for interfacing to their control box.....you also have to open the power supply and make connections for raw arc voltage on the main circuit board.
    If you order the plasma system with the machine torch....it comes equipped with the CPC machine interface.....and with that you can easily interface (and safely) to pins 3 and 4 ....which are the start input for mechanized use.
    You can order a kit (from any Hypertherm dealer) that allows you to add the CPC connector to any Powermax65 or 85...the kit comes with instructions....and is easy to install. 228696 is the Hypertherm part number...I am in an airport right now so I cannot easily look up the price....but I think it is in the $100 range. You also will need the connector or the interface cable that plugs into this CPC connector..228350 is the cable number....it is in the $80 range if I remember correctly.
    Hand held systems are designed by Hypertherm to be safely used for hand cutting, mechanized versions of these systems have a different torch and different interface in order to make them work best for machine cutting. Trust me....you will like the machine torch much better....and it will prove to be worth the expense. When you get the correct parts...I'll be happy to help you with the connections....email me directly if it is easier.
    The first picture is the PlasmaCam interface to my Powermax85.....all of the wiring plugs into the CPC interface connector on the rear panel. Second is the machine torch (with the mounting sleeve removed to make it shorter) mounted on a SnapnCut breakaway. No more broken torches.
    Jim Colt jim.colt@hypertherm.com
    Quote Originally Posted by jcplater View Post
    Attached Thumbnails Attached Thumbnails Jim Colt, Powermax 65 / 85 questions-powermax85install_008.jpg   Jim Colt, Powermax 65 / 85 questions-powermax85install_010.jpg
  • #18
    Apr 2012
    Thanks Jim and everyone else,
    I will be ordering the 2 hypertherm parts you listed and will let you know if I need any help when it comes time to wire this up. I ordered the Snap and cut break away holder already it looks like a great setup.
  • #19
    Jan 2008
    Sorry that this all wasn't clearer when you originally ordered the plasma system. We try to make the systems fit all of the applications as well as possible....but over 90% of these Powermax plasma systems are used for strictly hand held cutting.....so the components you needed are oprional fpor mechanized use.
    When you get the parts contact me directly....I will walk you through the best "plugnplay" interface to your machine.
    Jim Colt
  • Page 2 of 2 FirstFirst 12
    1. Colt Bosch Spindle
      By John Bear Ross in forum Taig Mills & Lathes
      Last Post: 02-08-2010, 12:30 PM
    2. Question for Jim Colt
      By plain ol Bill in forum General Waterjet
      Last Post: 10-03-2009, 08:09 AM
    3. Problem- kiwa 510 colt
      By davidtame in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 07-10-2009, 03:39 AM
    4. Problem- Kiwa 510 colt
      By davidtame in forum Fanuc
      Last Post: 07-10-2009, 03:36 AM
    5. TO JIM COLT
      By DISCONNECTED in forum General Waterjet
      Last Post: 09-26-2008, 10:38 PM
