Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 07-29-2010, 01:49 PM
mathx is on a distinguished road
Hypertherm torch touch
Hello,
I'd like to know if there's a way to detect when the torch's tip has touched the material (prior to starting it) with a powermax 1000.
I was thinking of building a probing electrical device, closing a relay when the tip of the torch touches the material, but the "body" of the T60 mechanized torch does not conduct to the tip.
Thanks.
Old 07-29-2010, 11:15 PM
jimcolt is on a distinguished road
Open up your operators manual.....go to the mechanized torch parts page...use the Ohmic retaining cap and the mechanized shield. The cap has a tab to attach a wire to, which is at the same potential as the shield. This has been used for many years on a variety of different height controls as an initial height sensing device.
Jim Colt Hypertherm
Old 08-10-2010, 11:40 AM
Beyond the ohmic cap (part #220061) do I need any other part that differs from the standard torch assembly? Because with just that cap (replacing the standard 120928 cap) the "tab" on the ohmic cap is not in contact with the torch's tip.
Thanks.
Old 08-10-2010, 12:07 PM
There should be electrical contact between the tab (for an electrical connector) on the cap, and the torch shield. There is no part called a tip (in a Hypertherm torch).
You should be using (for 60 Amp cutting) the 120930 shield, the 220061 retaining cap, the 120931 nozzle, 120926 electrode, 120925 swirl ring.
If you look closely at the retaining cap when all of the parts are installed on the torch...you will see a small tab that makes contact with the shield.
For other amperages follow the part numbers listed on the mechanized cut charts listed in your manual....if you are using fine cut parts...use the 220404 shield.
Jim Colt
hypertherm 1000 hand torch to machine torch duraflap Hypertherm Plasma 4 05-18-2010 02:34 PM
hypertherm torch and z axis woodman08 CNC Plasma and Waterjet Machines 0 12-09-2009 08:02 PM
Dia Hypertherm Torch? tof1 CNC Plasma and Waterjet Machines 2 05-08-2009 11:39 AM
Hypertherm Machine Torch Big John T CNC Plasma and Waterjet Machines 8 04-04-2008 10:20 AM
Hypertherm 1000 Machine Torch Help mattmu Plasma, EDM and other similar machine Project Log 9 12-21-2005 01:12 AM
