Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 07-20-2010, 10:57 AM
henryklassen is on a distinguished road
Green coloured pierce, short consumable life
D80 K2P0-0000
Plamsa PowerMax 1650 G3 Series
I'm having issues with short consumable life for example about every 15 pierces the nozzles is shot. During piercing there's a greenish colored flame around the torch and brownish smoke on the work piece. I've watched the air pressure and noticed that after turning up the pressure to 90 psi the pressure drops to about 75 psi during the cut. I have replaced the torch body with a new one and still have this issue. Any other ideas?
Old 07-20-2010, 11:37 AM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Sounds like the electrode and/or nozzle is being consumed. The green color is likely burning copper.
On out PM30, when the electrode is totally gone, we have the same symptoms. The cut is very poor, and it's much noisier than normal.
Paul
Old 07-20-2010, 11:47 AM
Paul
It's kind of hard to explain the pierce but imagine lighting about 20 match heads that's kind of what the pierces looks like and sounds like.It's always the nozzle that gets burnt up first.
Old 07-20-2010, 12:01 PM
Are you sure you have the correct electrodes?
I'm sure Jim Colt will be around to help you with your problem.
Take care,
Paul
Old 07-20-2010, 12:33 PM
Take care,
Paul
That was the first thing I asked the operator, and supervisor both said they did.
Old 07-20-2010, 01:18 PM
Take care,
Paul
Old 07-21-2010, 04:33 AM
jimcolt is on a distinguished road
Sounds like either the incorrect combination of consumables, a serious air pressure leak, or that the power supply has an issue with pilot arc current that is too high. I would suggest contacting Hypertherm tech service....it is free and they are very helpful.
Technical Service
technical.service@hypertherm.com
800-643-9878 Tel - Toll Free in USA
and Canada
Keep us posted on what you find.
Jim Colt Hypertherm
Old 07-21-2010, 07:49 AM
Will contact hypertherm, thank you for the help guys.
Old 08-13-2010, 04:39 PM
julio_gyn is on a distinguished road
I had a problem like that, it increased until the electrode blow on the first shot, the solution became very simple, I had very low coolant flow, a filter blocked...
Hypertherm consumable life - air cylinders energyforce CNC Plasma and Waterjet Machines 8 05-29-2009 12:59 PM
Hypertherm 1250 with a T100M torch??? Short consumable life Brink_ CNC Plasma and Waterjet Machines 18 01-08-2009 10:28 AM
Need Help!- Short consumable life Bigtoy302 CNC Plasma and Waterjet Machines 1 07-21-2008 11:25 PM
Optimizing consumable life, Improving cut quality Fiero Addiction CNC Plasma and Waterjet Machines 1 05-21-2008 10:14 AM
Hypertherm finecut consumable life bossfrog CNC Plasma and Waterjet Machines 9 10-25-2006 10:13 AM
