Originally Posted by
jimcolt
The Powermax 45 and Powermax1650 have the interface plug as standard on the rear panel, the Powermax65 and 85 have to be ordered with the interface in place (allows us to take crcuitry out of hand held units for more competitive pricing). On the 65 and 85 there is also a built in voltage divider (for THC use) with 5 different divider ratios....this way you do not have to bring raw arc voltage (just uner 300 vdc open circuit) out with your wiring...rather you can use a divided voltage between 20 and 50:1 ratio.
Hypertherms industrial plasma systems have far more complex interface capability....
Jim
