| Hypertherm Plasma Discuss hypertherm plasma machines here. |
I've been trying here in the UK with little success to find out more about the powermax (40 is it?) robotic/cnc interface. Sadly I'm afraid - getting any British companies to respond has been a little like pulling teeth - I suppose with the economy being so strong they don't need the business!!!!. So can anyone give me the following info or point me at the relevant literature. What exactly does the "robotic" interface give me? I'm hoping for: 1) the ability to control the torch on/off. Details? 2) a scaled down arc voltage. Details? 3) an arc good signal. Details ? All the info I've seen on the various hypertherm sites around the world say is: "CNC interface and Fast Connect™ torch connection increase versatility for handheld and mechanized usage" but any details appear to be "top secret". TIA |
| Nothing secret about the cnc interface which is included with all Powermax45 plasma systems. You can download the operators manual from the www.hypertherm.com (the only official Hypertherm site) site and it has all of the necessary info. Here is the info: There is a receptacle on the rear panel of the Powermax45 with 3 interface signals available. 1. Plasma Start. These 2 pins, when connected together (via a relay or switch) will fire the plasma torch, when they are disconnected, the plasma arc will stop. There are details in the manual that outline the typical circuitry to operate this input function if you are using a solid state device (transistor) to do the switching. This start function is only active when the machine torch is installed on the Powermax45. It is dangerous to have a remote switch when using a hand torch.....as the torch could be fired from a remote location when the torch is in hand. 2. Arc Transfer (also known as arc good, machine motion, etc.). These two pins are controlled by a relay inside the Powermax 45......when the plasma arc is transferred to metal that is attached to the work ground (ground clamp) the pins are essentially connected, when the arc is not cutting, the circuit is open. 3. Voltage Divider output. These two pins provide 1/50th of the actual DC arc voltage for use with many torch height control devices. Many devices require raw arc voltage, which is available on the main circuit board inside the unit. If you have further questions I would be happy to help, or you can call Hypertherm directly and ask for tech service. There are US and European tech service contacts listed on the website under "contact us". Best regards, Jim Colt |
| Jim - thanks for your reply Thanks for the info. I'll read and get back with more questions I'm sure but meanwhile do you have another link to the operators manual. I've never been able to download it - which is why I've never seen this info. I guess. It starts downloading and then just says "stopped" in the status bar (firefox). Cheers Ian |
| There is an available .pdf file and a .zip file for the manual. I have heard a few complaints that Firefox does not allow the .pdf (but some Firefox users say it works fine), however everyone tells me the zip file works fine. If that will not work, send me your direct email address and I'll email the .pdf ....it is in the 10 to 15 megabyte size range. Jim jim.colt@hypertherm.com |
| Jim - I'm wondering if I'm on to a loser trying to buy a hypertherm here in the UK. Do you know if they are available outside the US. Obviously if I do go ahead and get one and if I have to import from the USA then fine - I'm just a tad surprised I can't find a distributor this side of the pond. The only UK place I can find and I'm not sure if they're official resellers is a place called "city plasma" and they were the ones who wouldn't or couldn't give me the info I requested above - hardly fills me with confidence. Also do you know a ballpark price for a powermax 45 with machine torch - that would be usefull at this stage. I'm also assuming it's posible to import - are they ROHS compliant for example? and any other restriction the EU has put on things to try to close Europe down for good :-( Ian |
| Stirling, There are many distribution locations for Hypertherm products around the world as well as tech support and sales offices. In fact over 60% of our product is exported outside of the US. Have you tried location a UK distributor through the web site? www.hypertherm.com If that is not helping you....send me an email with your contact infor and I will make sure that someone from Hypertherm UK contacts you with a list of sources to purchase our machines. jim.colt@hypertherm.com Units that are shipped to Europe are CE approved units, and are designed to operate on your voltage and frequency. Using a system designed for use in the US would not meet the same specs as the US unit, and would not be properly designed for your power. All units that we produce are ROHS compliant, and have been for a few years. As far as pricing...the European price structure is a bt different as compared to the US. As soon as we find you a distributor, then figure out exactly what you need for a system....we can supply pricing. Best regards, Jim
| Jim - as per my email today, things are progressing nicely - thanks. Another techy question though re: the machine torch interface to the powermax45. The operator manual (and as you've already said) describes the scaled down arc voltage as being 50:1 and a max of 7V. My slight confusion here is that as I understand it arc voltage is negetive with respect to "clamp" so... Pins 5 and 6: is one of these at "clamp" volts and the other minus 7Vdc? with respect to "clamp" (if you see what I mean) Thanks Ian |
#10
| he he! - not really but I guess when I get my powermax45 I can figure it out.I need to take the potential difference between the two pins and feed that into an ADC which needs 0 to +5Vdc. I'm thinking that the "gnd" of the ADC will actually end up one way or the other wired to true ground so I need to figure out if I take "clamp" to true ground which I guess I will, then is that 7V above or below that? i.e. I need to a) sub-divide that 0-7V down to 0-5V and b) invert it. |
#11
| The cutting bed should always have a ground rod driven as close as possible, the work clamp from the plasma, and a heavy gauge wire from the ground rod to the cutting bed should be tied together at one place, called a star ground. It is confusing to many that plasma potential seems reversed as far as polarity, the work clamp can (and should) be considered ground even thogh it is the positive side of the circuit in reference to the negative (electrode) arc. |
| Problem- RHINO ROBOTICS ST/7 CNC LATHE | airamp | Benchtop Machines | 11 | 09-30-2011 09:46 PM |
| Microsoft Robotics Toolkit.. | datacop | Coding | 8 | 10-31-2010 08:58 AM |
| US First Robotics | cidteach | CNCzone Club House | 0 | 10-10-2007 10:54 AM |
| Adept Robotics System..not sure what to do with it | drewgarth | Servo Motors and Drives | 0 | 07-11-2006 07:22 AM |
| Durham robotics router Kit... | Rugby10 | DIY-CNC Router Table Machines | 0 | 03-07-2005 10:08 AM |
