Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 05-08-2010, 06:18 PM
JerseyBill is on a distinguished road
Plasma cutting copper sheet
I need to cut some .025 copper sheet and am looking for some suggested settings to begin with. I am using a Hypertherm 1000 and finecut consumables. The CNC table is a Torchmate 3. I've cut Aluminum, Stainless and steel but not copper. Certainly someone is cutting copper out there. This material is also much softer than anything that I've cut before. Any suggestions for supporting this sheet so it doesn't bend when the torch contacts it?
Old 05-23-2010, 11:20 AM
OK...I went with the test method to determine the settings. I started out with the settings used for sheet steel and adjusted them in an attempt to improve the cut quality. The settings that I ended up using were 30 amps, 80 arc volts and 140 IPM. I would describe the cut quality as "just OK" since there was some dross on the bottom of the cut. Making streight line test cuts doesn't always give you an accurate sample of the final cut on a file that has many curves and direction changes. Some of my streight cuts ended up with a bit of a saw tooth contour. Perhaps I could have improved the cut by turning off the height control after the pierce was complete. For supporting the material I inserted all of the support slate that the table had slots for. This gave me support every 3 inches.This was not enough to prevent the torch from bending the copper down and changing the pierce height. A possable work around would be to a thin sheet of aluminum or steet under the copper to help support it.
Old 05-25-2010, 01:03 PM
Edwardo is on a distinguished road
Thanks for the posts, i have been meaning to try out copper for some time now but havent gotten around to it. When i do i'll post what ever the results are.
EDD
Cutting copper sheet? bossfrog CNC Plasma and Waterjet Machines 3 09-02-2011 11:27 PM
HELP! CUtting sheet metal with plasma Sam4691 General Metalwork Discussion 1 07-13-2009 06:40 PM
Source for copper sheet? mc-motorsports General Metalwork Discussion 5 11-16-2007 01:33 AM
Cutting Aluminum or copper? Siren JGRO Router Table Design 1 02-23-2007 11:38 AM
Help machining copper sheet fastturbovet General Metalwork Discussion 2 03-26-2005 12:47 AM
