Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 03-31-2010, 06:40 PM
grogsroom is on a distinguished road
lead ins
hi jim just wanted to ask you about the lead ins and lead outs on my cnc plasma dxf files are starting their cut at the start of the lead in and cutting the lead outs , i have a hypertherm 1250 and the hypertherm phc with ohmic,i use flashcut and was wondering if you think i should switch to sheetcam,also the cuts are good on squares ,circles ,but when i cut anything fairly intricate it seems to not like it and shuts the torch off,any suggestions are great, thanks
Old 04-01-2010, 03:46 PM
jimcolt is on a distinguished road
I am not familiar with either Flashcut or Sheetcam....I can't help on this! I can suggest the best ways (from my experiences) to design lead ins and lead outs...if you show me what you are cutting!
Jim
Old 04-02-2010, 12:02 AM
woodman08's Avatar
woodman08 is on a distinguished road
lead in and lead out problems
we are using dxf files and when loaded in to flashcut the plasma torch cuts the lead in to the work piece and lead out crossing the work and ruining it,seems the torch is not being told to turn off and on at the proper timing.
I have enclosed a dxf file example
Would be very interested in how the lead in and out can be changed
Old 04-02-2010, 06:33 AM
I don't see any lead in, lead out on the file you sent.
Jim
Old 04-02-2010, 08:10 AM
woodman08's Avatar
lead in/out
when we cut this horse at say 6inx 6in there is 2 streaks after its done right across the bottom of the horse,not cut right through but like a scribe as the torch probably raised but did not turn off when it returned,our speed was 118 pierce delay .25 voltage 138.
we will try and send a result photo
also when i load the file i see the lead in ,i will get a screen copy and post it
Old 04-02-2010, 08:34 AM
woodman08's Avatar
screen shot
i cannot seem to upload the *.nc file that flashcut makes when you load a *.dxf but i feel flashcut is adding the lead ins/outs and the torch follows or maybe we have some setting on the torch wrong that its raising but not turning off.
This is happening to all files except a plain square cut or circle or star,anything more complex like a dog or horse it messes up.
I cannot get any answers yet from flashcut,but from you at least we're hearing the diagram (original)is clean
When the program finishes ,we get 2 streaks where i have shown the arrows
I checked on loading a *.dxf file and flashcut asks the size,the feedrate,the position (lowerleft) but then it asks decimal value--- join tol---- and chord error----which all
have default values (decimal_2,join tol_.002 in, chord error_.00100in)
Have not touched these values,but thats the only changes one can make before flashcut generates the code (*.nc file for it to use)
Would be nice to know what these mean and should there be an adjustment
stan
Old 04-02-2010, 10:14 AM
woodman08's Avatar
some photos showing the cut
the horse has a lot of cuts but its the two at the bottom ,we have been re-using material as the cost of this steel is up there
ID:	104312   Click image for larger version
Old 04-02-2010, 03:36 PM
Pandinus is on a distinguished road
It looks to me like a milling / routing post ... turn spindle on, route the whole thing, turn spindle off.
Just had a quick look at the flashcutCNC website and it looks like a milling system... it doesn't "Look" like its meant for plasma... and plasma is not listed under applications... So it wouldn't create leadins and leadouts and pierce cuts...
for starters you can manually edit the gcode.. remove the initial M3 and add a pierce before each Z"down" ... G1 to a Z height for your pierce and then (maybe) add a G4 (Dwell) for the Pierce delay... and ad an M5 before each Z"up" to stop the torch...
to create your Gcode you could try plasma777.com and try the DXF to Gcode, but you will have to edit the "post" section a little it has a section for starting the machine (file header)... moving to the pierce(lines 1-10)...starting the cut (lines 11-20) and stopping the cut (lines 21-30)... and finally stopping the machine... (file footer)
Its a bit of a thing to learn, but its free and I have had some luck with it so far...
It has a button to "SAVE PART" but so far I have not figured out what it does..
There is a tab to select a cutting order.. you have to click close to the leadins to select the path...
for example
the header could be your homing routine
G71 (set INCHES)
G90 (Absolute distance mode)
G91.1 (Incremental arcs)
the "MOVE"
LINE001:F50 (start move FEEDRATE 50)
LINE002:G1 Z5 (move to traverse height Z5)
LINE003:
LINE004:
LINE005:
LINE006:
LINE007:
LINE008:
LINE009:
LINE010: (end Move)
It will insert a G0 move here to the pierce point.....
LINE011:F200 (start cut FEEDRATE 200)
LINE012:G1 Z0.15 (Move to pierce height Z0.15
LINE013:M3 (Turn torch on)
LINE014:G4 P0.6 (Dwell .6 seconds)
LINE015:G0 Z0.06 (move to cut height Z.06)
LINE016:
LINE017:
LINE018:
LINE019:
LINE020: (end start cut)
It will insert G1 moves to perform the cut.....
LINE021:M5 (stop cut TURN TORCH OFF)
LINE022:F100 (FEEDRATE 100)
LINE023:G1 Z1 (Raise torch)
LINE024:
LINE025:
LINE026:
LINE027:
LINE028:
LINE029:
LINE030: (end stop cut)
And the footer could be
F100 G1 Z5
G0 X96 Y48 Z5 (Move the torch out of the way for loading unloading)
M30 (stop program and rewind)
If you have an initial height switch you could add the Z zero routine to the CUT section...
If you have a THC you might need to add the command to turn it on after your pierce...
ETC ETC
Old 04-02-2010, 04:03 PM
woodman08's Avatar
appreciate the comments and time spent
Have a hypertherm 1250 powermax with PHC hypertherm with ohmic for the z axis control.
The machine came with flashcut and in the setup there is flashcut milling and plasma or water .But i also feel flashcut is not the way for plasma.
We also own sheetcam but its not set up and i seem to get lost when i look at it .But i can have a quick look at the code
Old 04-02-2010, 04:08 PM
Well I'm kinda interested in sheetcam, haven't downloaded the demo tho.
Maybe you just need to set the post processor for flashcut to "plasma mode" then??? I don't know it or the PHC.
  #11   Ban this user!
Old 04-02-2010, 04:12 PM
this says something about plasma outputs
http://www.flashcutcnc.com/downloads...6_Addendum.pdf
  #12   Ban this user!
Old 04-02-2010, 04:21 PM
woodman08's Avatar
back
I have been told that sheetcam is very good and easy to configure ,i tired once and did not get far,but it does have flashcut as a recognized setting in nthe setup,and i have done that thyen loading a dxf file its good to go but thats the strange next step what makes it go ,there seems to be no start ,we have the newset sheercam.
That link you sent might be a help ,will look at that as ther are 5 items that want in input before you start the cut.
Thanks agin as we're going nuts here but we are close to a perfect cut
Problem- lead ins & lead outs mini1 CNC Plasma and Waterjet Machines 9 02-04-2009 08:51 AM
Need Help!- Lead In Lead out Speed Problem JWB_Machining Mastercam 5 12-12-2008 07:33 AM
How do you mount a lead screw/lead nut? jbluetooth DIY-CNC Router Table Machines 2 12-01-2008 04:10 PM
Need Help!- lead in/lead out Pure-Powder CNC Plasma and Waterjet Machines 4 06-03-2008 08:21 AM
lead in-lead out on surface toolpath Tugiyana Mastercam 4 05-07-2007 05:16 AM
