- Need Help!- HYPERTHERM MAX200 TORCH HARD ARC STATING
DEAR CNCzone member
i hope every body doing well ,
i have problem with my HYPERTHERM MAX200 TORCH is HARD ARC STATING EVEN THOUGH I HAD INSTALLED NEW CONSUMABLES AND CHECKED THE WORKPIECE CABLE
PLASMA PROPLEM VIDEO
تØ*ميل vid mp4
تØ*ميل VID2 mp4
THANKS
HOPE TO GET HELP
Re: HYPERTHERM MAX200 TORCH HARD ARC STATING
hello any body can reply me
Moderator
Contact Hypertherm technical service, they can help. technical.service@hypertherm.com or 1 800 643 9878 .
- Check that all of your consumables are manufactured by Hypertherm. Aftermarket parts are the #1 cause of misfiring.
- Check the condition of the spark gap assembly in the arc starting circuit (inside the power supply) and check the Pilot arc relay for dirty or worn contacts. Refer to operators manual.
- Ensure that you have the incoming gas pressure set correctly as well as the cut and shield pressures. Refer to operators manual.
Jim Colt Hypertherm
- You may not post replies
- You may not edit your posts
Forum Rules
