- Help with torch installation
I've recently installed the centricut quick disconnect torch (C107-1050) onto the plasma cutter I work with. Everything is installed & is operational, but for some reason it wont initiate an arc when I set the pierce height above 8mm. I'm thinking that I possibly set the torch too low and the THC thinks the torch height is higher? (Using the previous torch, I could set the pierce height to about 12mm, after which point I would have trouble getting the arc to initiate). When I installed the current torch, I marked on the torch body where the previous torch height was and proceeded to install to the same point. I've looked online for instructions on how to set the initial torch height but have had no luck. Do you guys have any info on how to set the initial torch height? and how to get the plasma to pierce at a greater height (one method I read was to have the arc initiate at one height and then set it to go higher for the duration of the pierce? (so that when youre cutting through e.g. 25 - 32mm the spatter doesnt destroy the shield).
- You may not post replies
- You may not edit your posts
Forum Rules
