- Need Help!- hypertherm powermax65 issue
Hello my friends This morning I turned on the equipment and the screen for the plasma said fault error 22. Normally when this would happen it was because the valve for the compressor was not turned on. This time the error would not clear. I changed some hoses and reconnected and nothing is happening. I opened up the system to see if I saw anything that might raise a red flag and everything seems normal. What did catch my attention is that the pressure switch is leaking air between the connectors but I don't know if that is normal or not. If I could get some help I would really appreciate it. The pressure of the compressor is the same as usual so no problem there.
Thank you in advance for your advice.
- You may not post replies
- You may not edit your posts
Forum Rules
