powermaz 45 issues(?)
Results 1 to 3 of 3
Thread: powermaz 45 issues(?)
    Sep 2003
    h Connecticut
    Default powermaz 45 issues(?)
    We purchased a used 4x8 table with a powermax 45 several months ago and have been working on improving the system.
    a few issues we have been trying to improve are ;
    proma THC set up (we got it as close as it will ever be considering the inexpensive hardware)
    angularity on thicker parts (played with cut height, feed speed, amperage, torch mount but still issues of angularity on 3/16 and 1/4 .... (we use "regular cut direction" for inside cuts & "reverse cut direction" for outside cuts
    holes out of round (we have implemented some rules in sheet cam for smaller holes) inconsistent results ....
    system is ;
    generic 4x8 table 20/20 extrusions style with water tray, ball bearings relatively tight system considering the hardware ....
    gecko drives
    generic steppers - z axis - y axis - x master & x slave
    mach3
    sheetcam
    proma thc
    3 phase 100 gal compressor for entire shop, running our other CNCs no problem, air drier. dedicated 60 gal reserve tank between air feed and plasma.
    hypertherm 45 with machine torch
    a newer problem encountered recently ;
    we had been cutting 1/4" test pieces relatively well ) except angularity, but decent cuts, minimal dross at about 60 ipm . test cuts were about 4"x4" or 2" dia holes, never long cuts ....
    We tried to cut a series of 3" x 18" gussets and could not get a decent result ;
    60 ipm - .8 s pierce - .15" pierce height - .06" cut height - Thc set to maintain approx .06" (also tried thc off same problems) - plasma set at 45 amps
    new consumables - dry air )
    cut starts well, proceeds through one long side then turns the corner and starts "gouging" for 3" then cuts through again...
    the "gouging" sometimes happens on the long end, sometimes on the short end.
    Cut always starts properly and cuts through for about 18 to 24" of cut before "gouging" ....
    Checked ground, even ground steel plate clean, everything ok...
    replaced consumables, lowered feed from 60 to 20 in 10 ipm increments, same problem ....
    wondering if it may be a duty cycle issue, but our experience with duty cycle and this machine is actual loss of arc after 30 min of cutting ....
    in this case we maintain arc but lose pierce and blow slag everywhere .... (ambient shop temp around 80F)
    We also experience huge angularity when 1/4" cuts are successful, no real improvement with height changes. Angularity is parallel from opposite edges, direction of cut seems to affect minimally. questioning the torch mount (machine screw clamp), shimmed square as best as possible, no real improvement...
    are we pushing the envelope a tad too far trying to cleanly cut 1/4" with this particular plasma model ?
    Any input greatly appreciated ....
    Pierre
    Pierre
    Moderator
    Jan 2008
    Default Re: powermaz 45 issues(?)
    Can you post a closeup picture of the torch nozzle and shield, showing the orifices on both on a set that did the gouging?
    - If the gouging always occurs after changing direction....the issue is likely a damaged nozzle, shield or a worn out retaining cap or swirl ring. Posting pics of the nozzle and shield will help me recognize where the issue is.
    - The book speed for using 45 amp shielded consumables is 48 ipm, for slightly better edge angularity drop to 45 ipm.
    - One pierce too close on 1/4" steel, or without adequate pierce delay will damage a nozzle orifice.
    - Be 100% sure the pierce height is being achieved.....pierce a bit higher if you are seeing some variation....as much as .020" is ok.
    - Install a pressure gauge on the rear panel air inlet. Watch this gauge during steady state cutting. The pressure while air flows at the torch must be between 90 psi and 120 psi at the inlet (do not trust gauge at your compressor...under flowing conditions it will read much higher than the pressure at the inlet, this is why I suggest installing a gauge hard plumbed at the inlet, and the size of your compressor has no impact on inlet pressure). Any drop during a cut will change the cut quality.
    -ensure no moisture is getting top the torch.
    - Do a test cut at the parameters you choose (speed, arc voltage, etc.) stop mid cut and physically measure torch height. If to low (should be .06") then increase arc voltage until height is correct. Don't expect the Proma THV arc voltage that achieves the correct steady state cut height to match the suggested voltage listed in the Hypertherm cut chart....these height controls seem to vary dramatically in my experience.
    Jim Colt Hypertherm
    Here is what 1/4" steel looks like when cut at the correct parameters (angularity of each side in marked) with a Powermax45:
    powermaz 45   issues(?)-powermax45-edge-angle-003-jpgpowermaz 45   issues(?)-powermax45-edge-angle-004-jpg
    Quote Originally Posted by Thermwood View Post
    system is ;
    gecko drives
    mach3
    sheetcam
    proma thc
    Pierre
    Sep 2003
    h Connecticut
    Jim,
    Thank you for your prompt answer.
    I am not near the machine.
    However, after a couple of bad cuts with used consumables, I replace the electrode and nozzle with new ones, Swirl ring and retaining cap are fairly new and look good. The shield has some wear but I did clean it and verified all orifices
    were open ....
    I will set a gauge to verify air pressure. Pressure at reserve tank is slightly above 90 psi. No sign of water ....
    For some reason, my chart indicates 60 ipm at 45amps for the T45M shielded ....
    Thanks will try your suggestions ....
    Pierre
