Need Help! Hypertherm Sensor Torch Height Control
Results 1 to 5 of 5
Thread: Hypertherm Sensor Torch Height Control
    Jun 2016
    Singapore
    Red face Hypertherm Sensor Torch Height Control
    good day to all,
    Need help with hypertherm THC. The machine i am working with seen to have a problem on the THC, the problem i was facing now is after the arc is transfer and start to move the torch lifter will start to move up until the arc cut off. Any advice on what i can check or do. Controller is using edge II with sensor THC PCB
    hope to get a replay asap from cnczone friends =)
    Moderator
    Jan 2008
    Default Re: Hypertherm Sensor Torch Height Control
    The Sensor has to read a voltage from the plasma cutter (you don't mention model)....usually a divided arc voltage at a 50:1 ratio. If the voltage divider has failed or you have a broken connection....the z axis will move upwards trying to achieve the correct voltage. Eventually the arc will be too long and will extinguish. Best bet is to work with the machine builder to sort this out. Jim Colt Hypertherm
    Mar 2011
    Texas
    Quote Originally Posted by jimcolt View Post
    I think my Sensor THC requires full voltage. I had to bypass the voltage divider.
    May 2014
    Francis
    What does the arc voltage readout on your controller say? Sounds like you are not getting feedback from the Ohmic sensor.
    Aug 2017
    Hi guys
    I want to fit hypertherm air arc glide thc to my plasma
    Does any one know the cost of that thc
    Hyp
