I can help you, have done a couple of Baileighs. If you can send me a copy of the suggested connection between the Baileigh and the Plasma (they sell Thermal Dynamics, not Hypertherm)....then I will help you with connections on the Hypertherm. There will likely be six wires, two are for plasma start, two for arc transferred (also called machine motion or arc good) and then if you have height control there will be two raw arc voltage connections. Baileigh has a few different models with different wiring....that is why I would need to see the suggested wiring for your machine. Jim Colt Hypertherm jim.colt@hypertherm.com
