Need Help! no pilot arc and cutting arc
Results 1 to 11 of 11
Thread: no pilot arc and cutting arc
    Oct 2014
    Default no pilot arc and cutting arc
    Hi everybody . i have some issue with my pilot arc. there is some problem with 400xd hypertherm.
    when i run the machine .the torch goes down touch the material making gas test and the machine doesnt cut the material
    no pilot arc and cutting arc .what does that cause about my problem. please help mee.
    Mar 2016
    Poland
    Default Re: no pilot arc and cutting arc
    The electrode, and cover are ok?
    The connector for high voltage (pilot arc) is clean?
    Oct 2014
    Quote Originally Posted by steryd View Post
    I actually changed the consumable parts with new one. Rechecked the o2 and air.i got the pilot arc but i cant get the cutting arc.i have suspicious about my chopper board o the hypertherm unit
    Mar 2016
    Poland
    Check mass connector
    Oct 2014
    i have attached you the video that you could figure it out .Thank you for your support...
    Mar 2016
    Poland
    Pilot arc looks fine, but stops very quick. Check air pressure and filters. There may be aproblem with hv set.
  7. #7
    Oct 2014
    i am gonna check it out . thank you for your coorperation and support.
  8. #8
    Aug 2004
    Brazil
    It would be good you rechecked the electrical conections between table and machine and then checked the Open Circuito Voltage for sure.
    Also check the parameters for pierce high.
  9. #9
    Mar 2016
    Quote Originally Posted by Alex S.A View Post
    +1 and if those check out, check the spark gap.
  10. #10
    jasonbourne1001's Avatar
    Dec 2014
    colorado
    i found the problem. the problem was in the hose some copper from the watertube. it has been stuck inside the oxygen hose.i removed it and there was no any problem....
  11. #11
    Member Dem1's Avatar
    Sep 2019
    Hi I have same problem with ht2000
    Still can't figure it out,
