Are you SURE you understand what the RS485 serial port does? The base line essential control signals are all via the CPC port. The serial port brings ADVANCED machine control; specifically, the ability to control the cut current (AMPS) dynamically from software and the Air Pressure. Things normally set via the knob on the Hypertherm manually. You can also get the error messages that are normally codes on the LCD. In order to use the serial port you have to have (obviously) the RS485 serial port on the Hypertherm, but you also need to have something for it to talk to (control software) on the THC or controller side and someway to integrate the control into the toolpath to make it effective. It talks a distinct dialect of RS385 so you don't just get an RS485 serial adapter for you control PC and start using it. All that being said:
1. Both of the kits you list are easy to install in the field. The CPC being the most important
2. The mini torch is shorter lighter and easier to mount (as you point out) however the cuts will be the same and the consumables are the same..
3. The 65 has a front panel torch cable plug. changing from one to the other is a 2 minute deal. The only difference is that a hand torch is wired to lockout remote firing via the CPC connector for safety issues.
TOMcaudle
Home
