Assuming you have clean, dry, oil free air you should be able to cut 5 to 10 sets (meaning cutting up to 150 of the 12" x 15" rectangles out of 1"). If you are destroying the shield...then you are not following the piercing specs in the manual. The pierce height is critical, and the pierce delay time is critical, I suspect one or both are not set correctly. You will get around 300 pierces on one set of consumables with the correct pierce height and delay time.
-Physically measure the pierce height, it is possible that your machine is not setting it accurately.
-Makes sure the full pierce delay times out before any Z (or x or y) axis movement occurs....the torch must stay in place until the arc has fully penetrated the plate.
Jim Colt Hypertherm jim.colt@hypertherm.com
