So I tried to jump the thing and it didn’t fire… however I also made a discovery on the CPC connector cable. I used a multimeter to check continuity from pins to the other end of the cable (inside the CNC box) and found that there is one cable that is not continuous. It’s the one marked red in the diagram below.
Could this be the problem??
