Hello,
There is some rumors that you can "cheat" the PMX45 by making a connection inside the hand torch, and it will act as a mech torch.
By making this, you can use a hand torch with a THC and the CPC connector without having to open the machine, and mess with high voltage or loosing the warranty.
a- open the hand torch at the fast-conect side
b- insert a pin (easy to get from older connectors from scratch) that is similar that the one used
c- using a wire clip (scotchloc splice) conect the wire from pin 3 (violet wire) to pin 4 (inserted pin)
The machine will think that is a mech torch connected instead of a hand torch.
Question: does someone tryed this, or this can damage the machine? I have a PMX45 but did not tryed (not yet...
Thank you!
