Results 1 to 9 of 9
Thread: Hydraulic Press for arcylic molds
    Jan 2011
    China
    Question Hydraulic Press for arcylic molds
    Hi guys,
    I was wondering where I could post a thread on making a hydraulic press
    for making acrylic discs molded into a custom design.
    I want to start this project and need some advice on design and thickness
    of the steel plating (L bar) that I'm going to use for the chassis design.
    Also I need some advice on making an aluminum mold out of 6061-T6 aluminum.
    I have a basic design in my head of the machine I want to build and will be posting up a design schematic in the next few days....
    I was thinking of going with 2 10 ton hydraulics pushing up one platform
    which would hold the aluminum mold. I plan to heat up the acrylic in a small
    mini oven and then take it out when it's soft enough to mold and place it in the mold and send the hydraulic controller platform up to press the acrylic into shape. Of course I would leave it there until the acrylic cools. Thats
    one reason why i'm using the aluminum mold to dissipate the heat quickly.
    Any suggestions on how I should go ahead with this design?
    Or any other comments anyone with experience could have for me?
    Thanks in advance.
    *Mad.
    Dec 2010
    Quote Originally Posted by TheMadScientist View Post
    Hi guys,
    Thanks in advance.
    *Mad.
    Hi Mad,
    You might consider making the die for your disks out of aluminum or steel filled epoxy. I do not know how long the dies would last but you should be able to get good detail. Be sure to use mold lubricant. You could make some nice casino type chips or souvenirs for an event.
    Jan 2011
    China
    I really don't know how to make a steel filled epoxy mold. I thought it would just be
    easier to make a press and just make them as described in my original post.
    In fact I get them made for me already here in China which is were I'm currently living.
    I have seen the way they make them so I just want to scale down exactly what they
    are doing and start making them for myself at home. At least I will have 100% control
    of the quality in production because they way they are doing it is they rush through the
    process to quickly which effects the quality and I'm not exactly happy with their quality
    job so time to get it done In-House!
    Dec 2010
    How long do you need the dies to last? You don't have to be specific but are the plastic disks you are making embossed with a pattern like a coin?
    It is easy to make the epoxy dies. If you keep a master then you could make replacement dies as they wear. It seems like what would matter is how many of them are being made and how quickly they need to be made.
    Jan 2011
    China
    Well, I guess to keep product costs down I would like them to last as long as possible. Currently they cnc a mold out of mdf and press it with that. But the
    problem is they don't wait long enough for it to cool down and the edges of the disc warp. Thats why I want to get a mold cnc'd in a shop here. That way
    the heat problem would be reduced and, I can make them in my home.
    How fast I can make them is not an issue as these are made for a very
    custom reason.
    I have attached a picture of the discs that I get made for me.
    They are 330mm in diam and 14mm in height.
    Attached Thumbnails Attached Thumbnails Hydraulic Press for arcylic molds-9-734.jpg
    Dec 2010
    custom reason.
    Well, with the epoxy die you could actually make and place a cooling coil within it so the mold would cool from within. Simple copper line or automotive brake line would work.
    Make sure you have a pressure limiting valve for your press.
    Jan 2011
    China
    would that valve be installed inline between the hydraulic and the pump?
    Dec 2010
    Yes, many are. Note that you want an adjustable one. Always check with the manufacturer of the relief valve for installation details.
    The hydraulic ram will probably already have a rubber plug in the outer wall. When that lets loose you would have probably already damaged the mold and bent your frame.
    Jan 2011
    China
    Cool, thanks for the advice on that... I hope to get my drawings up soon.
    1. Need Help!- Hydraulic Shop Press
      By diyengineer in forum Want To Buy...Need help!
      Last Post: 07-13-2010, 07:05 PM
    2. 1999 Piranha 65 Ton 8 Ft Hydraulic Press Brake
      By J-Mccoin 2009 in forum EBAY ADS
      Last Post: 11-04-2009, 11:08 AM
    3. Hydraulic Press- Component Help Needed
      By phil m in forum Mechanical Calculations/Engineering Design
      Last Post: 09-26-2008, 09:10 AM
    4. Homemade die clicker with hydraulic press?
      By leathersmith in forum Diemaking and Diecutting
      Last Post: 06-12-2008, 06:01 AM
    5. Primeline Hydraulic CNC Press brake
      By coalstove in forum Bending, Forging,Extrusion...
      Last Post: 09-13-2007, 07:58 AM
