Leaking Valves
Results 1 to 3 of 3
Thread: Leaking Valves
    Jun 2010
    Default Leaking Valves
    I work in a plant where we have several hydraulic systems. We always seem to be fighting hydraulic leaks. One system in particular we keep replacing o-rings between a valve with a DO5 pattern and the manifold block that it is sitting on with very limited success. Once we replace o-rings the leaks stop for a week or so then start dripping again. When we take the valves off to replace o-rings we often find the o-rings collapsed into the port. I am looking for suggestions to help solve this problem.
    Thanks in advance.
    David
    Mar 2008
    Default Re: Leaking Valves
    Get a bore scope and check out the valve internals.
    Sep 2009
    When you have the spool out of the valve body check for bore damage, bore scope works great for this. if there is room a good light works fine .Also check the spool for any damage especially around the edge of the o ring grooves. Something that works great for older hydraulic valves and other related equipment that uses o-rings is to switch to quad rings, most hydraulics supply shops have them.
    They have the same I.D/O.D sizes as regular O-rings the only difference is that O-rings have basically a single sealing face surface and quads have two.
    Quad rings are used in many new hydraulic controls.
    Hope this helps
Leaking Valves
Leaking Valves
