Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > HSMworks
HSMworks Discuss HSMworks CAM software here.
Old 05-27-2009, 08:48 PM
behindpropeller is on a distinguished road
2d Contour.....cuts on the inside.
Every time I do a 2D contour it wants to cut on the inside of the stock. I'm trying out the software and this is driving me nuts. It even does it on the tutorial!!
Help!!
Tim
Old 05-31-2009, 10:35 AM
shopvak is on a distinguished road
This is simple to change. In the geometry tool box, select the contour you want to change and click the reverse command below it. This will change the tool path direction to the inside and you will see the direction arrows change to the inside.
Problem- Contour help johny0407 Mastercam 1 05-14-2009 09:15 AM
frustration....plasma cuts off during cuts any ideas? gpnjuice CNC Plasma and Waterjet Machines 2 11-18-2007 07:45 PM
which cnc package cuts 2D parts with least extraneous cuts? mbwittig General CNC (Mill and Lathe) Control Software (NC) 3 05-06-2007 07:29 PM
Issue w/ Boss9 Post - Contour Cuts StickShifter Post Processors for MC 4 01-17-2006 08:10 AM
What's inside this box? Bloy2004 General Electronics Discussion 3 04-07-2004 10:07 PM
