Are you sure the spot drill is 90° and not 82°?
I'm trying to cut a 90 degree countersunk hole on an existing 3.1mm hole. The top diameter is set to be 7mm. I'm using a 3/8" spot drill to do the job. I selected the conical shape as the geometry and HSM set the height. However, the top diameter always come out to be about 1mm less than designed. Now I have to make it a 8mm top opening in solidworks to actually get it to 7mm. What did I miss here? Should I define a chamfer tool instead of the spot drill?
Thx in adv.
Daz
I would ask the same question as TheCamMan. If it is really 90 degrees then just use a drill toolpath and go 3.5mm deep.
Ben
Sent from my HTC6435LVW using Tapatalk
There is probably a flat on the bottom of your spot drill. I would measure that flat then draw your spot drill and measure the height of your spot drill from the tip to the diameter you want. Use a G82 drill cycle and put a dwell in the program.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
Wouldn't a spot drill need a point, rather than a flat, tip? I thought they were intended to start holes on flat surfaces, inch case you'd need a point on the end.
Mike
