Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > HSMworks
HSMworks Discuss HSMworks CAM software here.
Old 01-31-2012, 10:36 AM
mmprestine is on a distinguished road
Profile/2D Contour
Just checking out HSMxpress and have a basic question. If I want to 2D Contour (profile) a part how is it possible to set the depth of cut? If I create a contour it always goes to the full depth of the part and only a single pass. What am I missing?
Old 02-01-2012, 01:45 PM
cygnus x-1 is on a distinguished road
Under the heights tab, the "Bottom" setting determines the depth of cut. The default is to use the depth of the selected contour as the cut depth. But you can offset this, or choose one of the other methods for determining the depth.
There is a ton of useful information here:
Solid Code Solutions | HSMWorks Tips & Tricks
Some of them only apply to the full HSMWorks but many (if not most) apply to HSMXpress also.
C|
Old 02-02-2012, 08:20 AM
Thanks for the info. I was getting everything setup correctly but seemed to overlook the checkbox labeled "multiple depths", solved everthing. This allows a setting for setting the depth that the z-axis will cut per pass.
Old 02-02-2012, 12:54 PM
Ah, ok. There's that too.
C|
Problem- V24 profile contour ramping will not run finish gizmo_454 BobCad-Cam 17 01-13-2012 05:18 PM
Problem- This Contour Profile will not post. Others do... Trebol UG NX 1 10-26-2011 08:05 AM
Approach in contour or profile cuts 80083r EdgeCam 3 09-11-2009 09:23 AM
How to profile/contour and avoid areas? Shepard Mastercam 3 12-03-2007 05:11 PM
contour profile stevieboy Mastercam 8 10-15-2003 01:40 PM
