Running a Fadal 4020HT with CNC88HS control... I am using the "Generic Fadal" post in HSMWorks.... I have a few questions....
Below is the beginning of a very simple part:
O9999
(T1 D=0.204 CR=0. TAPER=118DEG - ZMIN=-0.8243 - DRILL)
(T2 D=0.196 CR=0. TAPER=118DEG - ZMIN=-0.7589 - DRILL)
(T3 D=0.375 CR=0. - ZMIN=-0.2599 - FLAT END MILL)
N100 G90 G94 G17
N110 G20
N120 G28 G91 Z0.
N130 G90
N140 M9
N150 T1 M6
N160 S5000 M3
N170 G4 P36
N180 E1
N190 M9
N200 G0 X1.3638 Y0.7874
N210 G43 Z0.6 H1
N220 G17
N230 G0 Z0.2
N240 G98 G73 X1.3638 Y0.7874 Z-0.8243 R0+0 Q0.051 P0.08 F28.
N250 X0. Y1.5748
N260 X-1.3638 Y0.7874
N270 Y-0.7874
N280 X0. Y-1.5748
N290 X1.3638 Y-0.7874
N300 G80
N310 Z0.6
N330 G28 G91 Z0.
N340 G90
N350 M9
N360 M1
N370 T2 M6
.........................and so on
Questions:
1.) need to have line numbers in front of comments...do I need to modify the post for this?
2.) Is there a Fadal post avail specifically for Format 1 / Format 2?
3.) Line 100 has a G90 for absolute, but then 120 switches to incremental and a G28, but then 130 goes back to G90...
4.) What is happening is that the tool goes down to just above the part, moves around a little, the raises way up in positive Z and does the tool path work...not sure why this is....?
Any insight / help on this? Thanks in advance....
Below is code from a different part that I created in another CAM package that works well:
N130 ( NC FILE - F:\PROJECTS\STACKMASTER\STACKMASTER II\CNC\SM1000-021-M410IB16)
N140 ( MATERIAL - ALUMINUM INCH - 2024 )
N150 G20
N160 G0 G17 G40 G49 G80 G90 H0 E0 Z0
N170 ( 3/4 FLAT ENDMILL SGS-SCARB TOOL - 3 DIA. OFF. - 3 LEN. - 3 DIA - 0)
N180 T3 M6
N190 A-0.
N200 G0 G90 S10000 M3 E1 X-5.5 Y-4.4999
N210 H3 Z.25 M8
N220 Z.1
N230 G1 Z-.125 F15.
N240 X-4.5 F220.
N250 X4.5
N260 Y-3.9374
N270 X-4.5
N280 Y-3.3749
N290 X4.5
N300 Y-2.8124
N310 X-4.5
N320 Y-2.25
N330 X-.6904
.............................and so on
LinkBack URL
About LinkBacks
