Results 1 to 4 of 4
Thread: HSMWorks 2011 Released today
    Dec 2009
    HSMWorks 2011 was released earlier today. If you have an evaluation, just download it. If you need an evaluation code, you can request one at NexGen Manufacturing Systems, Inc. HSMWorks The CAM System for SolidWorks or HSMWorks - The CAM Solution for SolidWorks
    Charles Davis
    NexGenCAM, Inc.
    Apr 2008
    Great news!
    Can you post the change list? If you click on the history link, it just takes you to the download page.
    Gabe
    Dec 2009
    Change List
    I should have a Newsletter out this week. Maybe I should include a link to a revision list? HSM has rolled out many of the changes throughout the year, so what might be most useful would be a list from 2010 R1 to 2011 R1. Let me see what I can put together.
    Charles Davis
    NexGenCAM, Inc.
    Oct 2010
    Hi Gabe,
    While we have not comprised a complete list from the initial release of HSMWorks 2010 to the initial release of 2011 the following is a look at a number of changes that were presnt as soon as we started beta testing HSMWorks 2011 R0 (Beta). This verbatim list is dated September 03 2010.
    • SolidWorks 2011 is now supported.
    • A new ramping option called "Plunge outside stock" has been added for 3D pocket.
    • Stock boundaries can now be specified to do core roughing with 3D pocket.
    • Predrill ramping option is now available for 2D pocket.
    • Minimum cutting radius used to round inner corners is now available for 3D contour.
    • Added support for left and right compensation for 3D path.
    • Left and right compensation is now available for multi-axis contour.
    • A new flow strategy is now available. Flow supports 3-axis, 4-axis, and 5-axis machining.
    • Added support for selecting same color faces.
    • Added support for face and chamfer tool for most milling strategies.
    • Added support for manual NC (i.e. for outputting comments and simple commands) operations.
    • Added support for "must touch check surface" (name subject to change).
    Keith Clausen
    Solid Code Solutions
  1. Solidcam vs HSMworks
    By mattpatt in forum SolidCam
    Last Post: 03-21-2011, 03:09 PM
  2. EdgeCam 2011 R1 Released
    By tummen in forum EdgeCam
    Last Post: 10-31-2010, 03:06 AM
  3. hsmworks
    By sger in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 08-24-2010, 05:46 AM
  4. Anyone tried HSMworks?
    By shopvak in forum HSMworks
    Last Post: 12-10-2009, 01:41 PM
  5. V11 User Guide released today
    By scadvice in forum Alibre Design
    Last Post: 02-03-2009, 09:57 PM
