Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 02-15-2010, 11:34 PM
jdgbadenhorst is on a distinguished road
Only Y works correct X don't work Z works one direction only
Hi
I have a mill with 3 axis pro board,(Hobbycnc) the mill worked great 4 years ago after moving and atorage and rebuild - now I only get Y axes to work
right
X Axis :
No movement but it locks up
I have the 3A steppers on the masjine so the motor setting on the board should be set to 0.42v but if set to maksimum - I only get 0.23v - Both Y and Z axis are set to 0.42v
The question is - why only 0.23v and is this why X dont move
The 5v test gives 5.03v
Z Axis :
Moves only in one direction does not matter if Mach 3 are told to move up or
down Z just move up
Is this becouse of above problem with X or is this something else
Using mach 3
EPP printer port
Mach3 are set pin 3 = x step, 2 = x dir 5 = y step 4= y dir 7 = z step 6 = z dir
Please help
Old 05-20-2012, 06:26 PM
bourneash is on a distinguished road
Hi, I am have the exact same problem, spent many hours trying to figure it out..... ever fix yours?
The engine works but only in one direction Marfon LinuxCNC (formerly EMC2) 0 11-29-2008 01:44 PM
Can someone tell me how this PIC works? KPyro Stepper Motors and Drives 10 12-09-2006 03:48 PM
Another one in the works.. CRFultz CNC Wood Router Project Log 31 12-23-2004 01:09 AM
It's done (and it works!) Joe Petro DIY-CNC Router Table Machines 4 01-09-2004 01:07 PM
How does G 41, G42 works ? BanglaTech General CAM Discussion 7 11-04-2003 11:38 AM
