| Hobbycnc (Products) Discuss Hobbycnc controller boards here. |
Hi Guys I`m new to all this and just starting out - I have myself 3 motors - Nema 23 the first ones at the top of this page: http://web.archive.org/web/200503180...com/page3.html I purchased them off someone else, not from new and so they are wired bipolar parallel. As a noob, I just want to get them running and I am considering buying the EZ HobbyCNC driver 4 axis. Now I realise my motors are bi-polar and that the board is a uni-polar but will is still work or will I need to rewire the motors? Help and advice appareciate. Chris |
| Jeff No, they are 8 wire bipolar - it is the unipolar / bipolar thing I don`t understand. What will be the "issue" that probably will make this drive not the ideal piece of kit? I heard that ideally I should be using bipolar driver with bipolar motor... Any more advice welcome. |
| Chris, If you can attach longer wires to the six existing wires you will be able to use the HobbyCNC drive. Jeff..
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| If they are either 6 or 8 wire motors, they can be configured to run either Unipolar or Bipolar. Take a look at this link for more detailed information on how to do so: http://www.probotix.com/stepper_moto...polar_bipolar/ |
Yes you could use the the motors that you have with the Hobbycnc board. The taped wires would be the common or power source to each phase, but one draw back the motors are rated at 4 amps per phase the Hobbycnc board has a max of 3 amps per phase so you would not get the full 189oz torque from the motors. Recommend using Hobbycnc motors rated 305oz and 3 amps per phase if you have board already. If you don't then puchase one of Hobbycnc cnc packges which would require assembly/soldering. For a few dollars more you could get a plug n play package from mikebeck.org, same Hobbycnc package but has been assemble and tested. I puchase the 4 axis 305oz Hobbycnc Pro package from Dave because I had the power tranny and enclouser on hand and I am very please with the system. Harold |
| Unipolar Stepper run with Bipolar Driver | bcromwell | General Electronics Discussion | 38 | 11-26-2009 04:10 AM |
| HobbyCNC Unipolar Chopper Driver Kit! | HobbyCNC | Product Announcements & Manufacturer News | 1 | 11-09-2009 08:40 PM |
| Use of unipolar as bipolar or unipolar? | DigiSoft | DIY-CNC Router Table Machines | 2 | 03-17-2008 02:23 PM |
| unipolar to bipolar | tekno | Stepper Motors and Drives | 8 | 03-12-2006 08:42 PM |
| Unipolar and bipolar ? | venomx999 | Mechanical Calculations/Engineering Design | 1 | 11-23-2005 02:22 AM |
