Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 01-21-2005, 08:42 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
HobbyCNC 3 axis controller board review
I have a HobbyCNC 3 axis board on the way that I plan on doing a build thread in this thread. I'll post pics as I'm building and finally how it works. So stay tuned. Mind you I'm not a electronics guru, I know how to solder and follow directions, so this will be a good opportunity for those nervous to try out assembling electronics. This new board is lated for my new laser design. For more info check out http://hobbycnc.com , tell him cnczone sent you.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-26-2005, 01:12 PM
CNCadmin's Avatar
Site Owner
I received this kit http://www.hobbycnc.com/cncpackages/...g/4aupcpkg.htm today.
Included with our 3 or 4 axis chopper driver board KIT (4AUPC) are the required components to operate 3 or 4 steppers rated at up to 3A at up to 43VDC. Included in the package is a cooling fan and guard, DB25 Parallel Port Cable, stepper motor cable, hookup wire, fuse holders and fuses, filter capacitor, switch, 35A 600V bridge diode, heat shrink tubing for the motor/cable splices, grommets, labels, ALL hardware, instructions, wiring diagram, and full size template drawings to help eliminate layout errors! Case and 10A transformer are not included. All other components and hardware is included. Only a computer, software, soldering iron, solder, case, transformer, and tape are not.
Everything was very well packed in their own bags. I looked briefly through the manual and found that to be very well written and with very good wiring and hook-up diagrams.
I will upload some pictures tonight and hopfully will start the soldering. Stay tuned...
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-26-2005, 07:31 PM
anoel's Avatar
anoel is on a distinguished road
I bought, built and am using that board. Very nice... Works exactly as it should. This is the 4th Controller I've used and I'm more than happy with everything about it, including customer support.
Nathan
Old 01-26-2005, 10:21 PM
CNCadmin's Avatar
Site Owner
Here is a picture of what I got-
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-26-2005, 11:26 PM
CNCadmin's Avatar
Site Owner
1/2 hour later and here is the board-
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-27-2005, 02:48 AM
*Registered*
HobbyCNC is on a distinguished road
Assembly Photo
Paul,
Looking at the picture I see a few things that concern me. Capacitors C5 and C6 are not installed while C4 is. Step # 6 states to install C1, 2, 3, 5, and 6.
Secondly, TB4 is installed on the 4th axis...you have the 3 axis version. Did you install it there in error? TB5 should be installed by now...(Is it in TB4 position?)
Thirdly, RN5 should be installed by now...You didn't install it in RN4 location did you?
Dave Rigotti
Hobbycnc.com
Old 01-27-2005, 08:32 AM
CNCadmin's Avatar
Site Owner
Originally Posted by hobbycnc
Paul,
Dave Rigotti
Hobbycnc.com
Well I did do this at 11:00 pm and I was tired, so yes your right, I have a few parts miss placed oops, I would have figured that out today, we I go to test the voltage. Thanks for pointing it out, I have a friend who is a electrical engineer, he will have a look at it before I put any juice to it and he will be able to test the board and put it through it paces.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-27-2005, 08:38 AM
CNCadmin's Avatar
Site Owner
BTW to all of you newbies to solder your own electronic this is a great lesson, I'm not new to soldering circuit boards, I have done quite a few, double check your work, than check and check again. It's SO easy to make mistakes, even if your supper careful, recheck before you add power, if not the end result will be smoke and maybe fire but mostly smoke. AND RTD (Read The Directions)
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-27-2005, 08:45 AM
*Registered User*
lurch is on a distinguished road
Talking Late night soldering....
I made a similar placement error on the same board. Though I took four times as long, and I realized my mistake in placement before soldering down the component. I went through the instructions several times before beginning, inventoried the components, and placed them in order relative to assembly order, this took more time, but made it completely painless.
This was my first board of any size. With a little care and some patience it went very well, tested out right the first time. Dave was quick to respond to any questions I had. I couldn't be more pleased with the kit! Thanks, Dave!!
Old 01-27-2005, 09:50 AM
dwwright is on a distinguished road
HobbyCNC Board
I also bought the 3-axis board. I've been very happy with it and had no issues building it as the instructions were very good. I do regret not buying the 4-axis board and have asked Dave about a kit for upgrading. He said it would be a while before he would have time to look at putting one together. I also wish I had known he was going to offer 200 oz/in. motors as I would had rather bought them instead of the 80 oz/in. I'll eventually build another machine and will probably go with the HobbyCNC again as I've had very good luck with it.
Darren
Old 01-27-2005, 07:28 PM
*Registered*
Darren
Darren,
What can I say...Our policy is to never pre-announce any new products. "gives the competition a unnecessary head start!"
Dave Rigotti
  #12   Ban this user!
Old 01-27-2005, 11:04 PM
Jay C is on a distinguished road
Guys I apologize if this si the wrong thread for this type of question, but in trying to decide where you put your money it's prudent to ask. If need be, I'll remove this post, but here goes:
What is the difference in the HobbyCNC product versus the xylotex product? Is it a question of speed, efficiency, robustness, ease of use? What features should one be weighing when they decide on a driver board? I was thinking of making my own CNC router, but the more I read, the more I think that a converted mill would be a better choice for me (like the Taig). However, I'm the kind that analyzes everything so ...
Thanks in advance,
Jay
3 axis stepper motor controller board - question Yellowbeard Stepper Motors and Drives 17 04-06-2005 11:02 PM
Looking for controller board for synchronized stepper motors Yellowbeard General Electronics Discussion 0 04-02-2005 09:50 AM
HobbyCNC 3 axis board build and review Jay C Hobbycnc (Products) 19 02-18-2005 11:22 PM
4th axis controller board? CNCadmin DeskCNC Controller Board 1 08-30-2004 04:38 PM
