| Hobbycnc (Products) Discuss Hobbycnc controller boards here. |
Hello now i'm pretty confused.. I got the 3axis 4aupc driver board and the 80oz steppers from hobbycnc Now when reading the label it says 6V 1.2A on the stepper motors while the driver board minimun specs says 12VDC input max 44VDC.. Recomended 30VDC 10A but can the steppers really take that? /Loterus |
| I think if you search through these forums, there are plenty of explanations on why & how. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| The short answer is yes, those steppers will handle 30VDC very well. They will only draw 1.2 amps so too many amps on the power supply doesn't hurt. It just costs more. Like Al said, your question has been answered many times on this forum. I don't remember the specifics, but you should be able to go 6x the rated voltage, in fact, its preferable to be at least 4X |
The driver chips on the board can handle around 44 volts dc at about 3 amps per phase on the motor being driven. The board has on board current limiting settings to allow you to set a max amps per coil for each axis. This will keep the amps from frying your motors. The voltage your motors can handle is not something you should have to worry over as they can usually handle quite a few times the stated voltage on the nameplate on the motor. The controller board does alot of the work for you though. Pay close attention to, and follow your directions. Dave Rigotti is great with his support of the board! I can't say enough about his responsiveness to support his customers in troubleshooting, and setup, as well as just plain customer service after the sale!! You might also check into joining the yahoo hobbycnc group open for daves customers. It's a great place to find support, and good discussion on setup, and performance.... |
| I have soldered it together now and tested running it with a computer psu just to see that its working.. and it works! motors run pretty slow and arent so strong so they shurly need more power.. thx for the yahoo group tip! |
| That is the beauty of a chopper driver. The higher the voltage the faster the motor will go. The Hobby CNC requires a minimum of 12VDC to operate correctly. It will run the 6 volt motor by chopping the current when it is sensed by the chopper. The important thing is to see the Vref before connecting a stepper. I am using 36V on a 3 V motor. Dan Camtronics Inc
__________________ Dan Mauch Camtronics Inc dmauch@seanet.com www.seanet.com/~dmauch |
How did you like the kit? Dave Rigotti |
| Yes I did like the kit. It went together in about an hour. I was surprised at how well the drivers workded in the 8 microstep mode. I am currently making a modification so that I can incorporate an all windings off feature. And when I get some time I want to try to implement a reduced current mode. Dan Camtronics Inc
| Hooking up HobbyCNC board and motors to PC... | jdbaker | Hobbycnc (Products) | 7 | 06-06-2005 02:10 PM |
| Have existing stepper motors but want to replace control board with integral drivers. | Gerald_D | General Electronics Discussion | 3 | 05-22-2005 10:55 AM |
| Does anyone know of a controller board for synchronized stepper motors | Yellowbeard | Stepper Motors and Drives | 2 | 04-04-2005 12:06 AM |
| Looking for controller board for synchronized stepper motors | Yellowbeard | General Electronics Discussion | 0 | 04-02-2005 09:50 AM |
| Fun with floppy stepper and driver | Konstantin | General Electronics Discussion | 5 | 03-08-2004 02:18 AM |
