Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 12-13-2008, 09:28 PM
radcliffe is on a distinguished road
NEED HELP: Wiring for Hobbycnc FoamPro and bow power
I'm no electronic or electrical Guy I need help in wiring power supply and bow power for Hobbycnc foam pro board.
US 100-120 3 prong power cord.
1. neutral = white ?
2. load = black ?
3. Ground = green
MPJA SWITCHING POWER SUPPLY INPUT TERMINALS LABEL AS L - N - GRD. SYMBOL. The terminal marked with the grd. symbol is that the third leg of the 240 circuit and not the true grd of the US 120 circuit.
If someone could look at pdf drawing and let me know what needs to be corrected.
Bow power: should I have a bleed Resistor along with the caps.
Should the Bow fuse be before the bow power in on the foam pro board or on the bow out side.
I have a panel mount 0-5 amp. meter that I would like to install. Is it correct to hook it up in series with pos. + out.
Any and all help will be appreciated.
Harold
Newbie- HobbyCNC EZ board - Power Supplies themonster Hobbycnc (Products) 3 07-14-2008 12:16 PM
modify HobbyCNC pro board power unit and datasheet suwat Hobbycnc (Products) 0 08-09-2007 05:15 AM
Hobbycnc Power Supply vulcom1 CNC Wire Foam Cutter Machines 0 05-03-2007 03:29 PM
HobbyCNC wiring details lgroulx200 Hobbycnc (Products) 10 12-14-2006 02:58 AM
HobbyCNC wiring details CNCadmin DIY-CNC Router Table Machines 0 11-27-2006 10:00 AM
