Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 08-07-2008, 08:15 PM
chris_mc_nair is on a distinguished road
Can anybody please help on Powermax 1.8deg step motors?
Hello All,
I am having one heck of a time getting my 4axis wire cutter working.
I have a Hobby CNC rev0 4axis control board, Foamlinx machine with origional Powermax 1.8deg step motors, these are not the powermax II motors that you can find all the info on.
My machine came with no wires, I have managed to get a set of 8 wire plugs I just cant find out the exact wire schematic from the servo to the control board.
Can anybody help me on this issue?
Thanks in advance,
Chris McNair
Old 08-08-2008, 04:11 PM
Jay C is on a distinguished road
Well first you say step motors, then you say servo.
The wiring of an 8-wire stepper is below. Since your motor may not match the color coding, you'll need a ohm meter to determine what leads go with what coil.
Is the ohmage pasted on the motors you have?
Jay
Old 08-08-2008, 05:55 PM
Jay
Jay,
Sorry about that, rookie mistake....
I have a ohm meter but I will look at the motor and see if there is any indication of ohmage on the label.
Would it be easier to post a pic of the motor?
Thank you for your response!
Chris McNair
Old 08-08-2008, 07:07 PM
Yes post a photo. Have a look at the attached image. This is from the powermax datasheet.
ID:	64484   Click image for larger version
Old 08-08-2008, 07:13 PM
ger21's Avatar
Post the model # if you have it.
Old 08-08-2008, 09:16 PM
OK, here is a pic of the step motors I have.
I am also attaching a pic of my wire and harness, I am not sure but I am assuming that the pin on the left is #1 Pins 2 and 5 are jumped as well as pins 4 and 7, this is the way I received them.
Thank you again for your help.
Chris McNair
ID:	64498   Click image for larger version
Old 08-08-2008, 09:25 PM
ger21's Avatar
This has all the info you need.
http://www.xylotex.com/PacSciDS.pdf
ID:	64501   Click image for larger version
Old 08-08-2008, 10:02 PM
Thank you! It is very much appreciated.
Chris
Old 08-08-2008, 11:04 PM
The PAC SCI pdf too
Old 08-09-2008, 01:30 AM
The PAC SCI pdf too
Thanks Man!
I am at the point now where I know what pins are what and how its wired, I have checked the control board to the specs the manufacture gave, I have the correct voltage where is needed and have set the pots to the .300-.302
My concern now is that when I meter voltage at the pins with the control board on I can make it see 18+V dependent on how I place the + and -.
Would anybody happen to know what the voltage is supposed to be at the plug? Do I need to keep ground on Pin 6 at all times and check + only? If this is confusing I will do my best to explain better.
Thank you,
Chris McNair
  #11   Ban this user!
Old 08-09-2008, 09:11 AM
So now I'm confused. What are you trying to do exactly? The Common is V+, each phase on the coils will be grounded or "open" depending on the step sequence. Is it not stepping ... likely cause is the driver is blown ... just like my Z-axis on my HCNCPro last night
Jay
  #12   Ban this user!
Old 08-09-2008, 11:07 AM
Jay
Jay,
I will try again, It is very possible there is a issue with the driver, this was a unit bought by a guy a few years back, he never used it because he got his larger unit up and working. I bought it off him with the knowledge there may be a driver issue, I have a second driver that I built, it shows the same voltages as the current driver I am using. Unfortunately they are Rev0 Hobby CNC drivers so they are a little out of date.
I guess I will look at a new driver, you have any good suggestions?
Thanks again,
Chris
Step Syn Motors hpapilot Stepper Motors and Drives 6 09-04-2007 07:06 PM
I got the step motors so what's next rbocaz CNC Plasma and Waterjet Machines 2 08-14-2006 11:04 AM
Step-Syn Motors lilwen Stepper Motors and Drives 4 07-02-2006 09:17 PM
Before buy the Step Motors. samsagaz Stepper Motors and Drives 3 03-28-2005 05:50 PM
Do you have a question regarding step motors? ESjaavik Stepper Motors and Drives 0 03-24-2005 01:51 AM
