Results 1 to 2 of 2
Thread: Motor screams and gets hot while idle
    Apr 2006
    SWEDEN
    Hi.
    Took me 3 years to get this far but i am starting to se some results at last.
    I've started converson of a Proxxon MF70 and last night i connected the first axle
    But when i powered the card the motor started screaming in a very high pitch which got lower and lower until it stopped after aminute or so, and it got too warm to hold.
    Is this normal?
    It seems to work anyway since i can jog it and the driver on the board IS touchable so its not that hot.
    The motor name is TEC SPH-54AB-090 (have not data sheet for it thou, its from some printer)
    Running from a 12V 8Ah ATX psu.
    Using a 2 years old hobbycnc card
    /Ulf
    Apr 2006
    SWEDEN
    okey no matter. It's as supposed to be. it gets hot during idle. i've gotten answers from another place.
    /Methuso
  1. use satellite dish actuator motor as a stepper motor
    By ozni in forum Stepper Motors and Drives
    Last Post: 06-18-2010, 08:55 PM
  2. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-24-2010, 07:12 PM
  3. G201, no holding power at idle
    By Zumba in forum Gecko Drives
    Last Post: 02-21-2008, 01:26 PM
  4. automatic idle-current reduction & belt drive ??
    By Georg in forum DIY CNC Router Table Machines
    Last Post: 11-06-2007, 04:11 PM
  5. Whine / squeal noises when machine idle
    By bkraz in forum Bridgeport and Hardinge Mills
    Last Post: 02-09-2006, 06:29 AM
